Question about Rinnai EnergySaver 556 Air Conditioner
Rinnai EnergySaver 556F Heater flashes
Just moved into an apt with this heater in the living room and when I turned it on for the first time last night it heated up nicely - but after awhile all the lights on it (ON button and the lights above the temperature) began blinking on and off until I shut it off. Is this normal? I have no manual.
  • 2 more comments
  • DevonA Nov 16, 2007
    Thank you for the manual.
    When the lights are blinking there is no heat blowing from the unit. The Temperature buttons do not work. If I shut it off and turn it back on, it resets to 68 degrees, as programmed, and shortly begins blowing hot air with no problem.
    It is not the filter light and the filter is clean and inserted properly.
    I note in the manual, it says "If the heater does not ignite within 15 seconds the spark will stop and the 'Temperature level' lamps will flash. Turn off and repeat ignition operation."
    My unit does work fine initially and for hours - so it is not the first ignition. For some reason could I be losing the spark? When I turn off and on, it works again for hours.
  • rjdebellis Nov 04, 2008
    556F Heater flashes lights and will not turn on.
  • Anonymous Dec 20, 2008
    does propane gas line freeze
  • Anonymous Dec 31, 2008
    With our current Rinnai heating system, the lights will flash after a while and act like the filter is not clean. However, I have personally cleaned it form time to time but am unable to fully take it out to clean it. I am not sure why it does this or how to fix it. what could be wrong with it.
I'm picking up a faint propane scent when the heater is completely turned off. When I turn the heater on it lights fine so I don't suspect it's the pilot light. Is this an issue with the installation of the fuel line, or could it still be the pilot? Any ideas on troubleshooting the source?
Posted on May 26, 2008
  • 1,420 Answers
This may be normal but lets get you a copy of the owners manual to make sure. Try the link below. You did not mention if the unit still produces heat or not. If not, let us know and we will do our best in helping you.
Posted on Nov 13, 2007
  • Chandler Ede
    Chandler Ede Nov 17, 2007
    In the manual it will give you a procedure to recall the error codes stored in the memory. Get a pencil in hand and be prepared to write them down. If will help if a friend writes them down. I think you have to press a few buttons together to get the error codes. From there it may stear you in which direction to head in for repair.
Rinnai DV Propain Heater 556F
Sounds like the relay might be going bad and needs to be replaced
Apr 10, 2008 | Rinnai EnergySaver 556 Air Conditioner
I have a Rinnai 556F Heater and I set it to a specific Temperature and a temperature higher is always flashing. What is wrong?
The temp you are looking at may be an error code. 72 Room sensor, 68 Over heat, 76.80 Room sensor short, etc. What is the exact code??
Oct 14, 2010 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Rinnai energysaver 556f manual
Here is a link to the 556FTR from Australia.
They are all pretty much the same. The US site has similar info. Just google Rinnai. Open the site, go to resources tab and click downloads. The manuals are easy to locate.
Jul 27, 2010 | Panasonic Heating & Cooling
My tank says I have 32 gallons left but the heater won't work (rinnai 556f). It turns on for about 15 seconds and the light on the power button turns red and starts blinking. What does this mean?
If you hold down the economy button and the up and down arrow buttons for 5 seconds the unit will start an error code display. Get a helper and yell out the numbers when they start blinking. Post the error codes and we can help you
Dec 23, 2009 | Rinnai EnergySaver 556 Air Conditioner
I am needing an instruction manual for rinnai energysaver 556/FTR as have purchased and moved into property recently and am having trouble operating the heater and am concerned with a red filter light that...
navigate to tradesmart, space heating, energysavers.
Red filter light means the filter is blocked.
its located directly on the back of the heater and the wall spacer, from the control panel, its about 4 inches back.
Pull it up, clean reinstall
Apr 27, 2009 | Heating & Cooling
I have a Rinnai 308FTR heater and the first time I
Means failed ignition/no gas.
Check gas supply.
Mar 05, 2009 | Heating & Cooling
Rinnai 556F Not Exactly and "Energy Saver"...
Raise the thermistor. It is a black rubber probe located on the back of the heater close to the coldest spot in your home, the floor. Raise it a few inches. To do this you will need to unhook it from its holder and open the front of the heater to unravel the extra length of yellow wire.
Jan 24, 2009 | Rinnai RHFE-556WTA Direct Vent Heater NG...
I have a Rinnai Energysaver 556F
The heater will have some error codes stored in it. To retrieve them get an assistant to write down the codes as you see them. They come quickly. OK to get the codes, push down on the Economy button and the up arrow and down arrow at the same time. Hold for three seconds. It will take three fingers to do this. Once you get the error codes, look in your owners manual to diagnose.
Nov 21, 2008 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Rinnai EnergySaver 556 Air Conditioner Logo
5,429 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
