Question about Sony KP-65WV700 65" Rear Projection HDTV
The screen turns red after being on for about 30 minutes
  • ghettochild Nov 26, 2007
    I'm having the exact same problem. It just happened last night. Screen gradually turns red and the shuts off.
  • 4,402 Answers
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Posted on Jan 23, 2008
My Sony big screen rear projection TV model KP=51HW40 produced 2002 screen flashes red then shuts off. We can turn it back on and it will run for 30-60 minutes and then it repeats red flash. Is this
The Problem you are having is a Cathode to Grid Short in the Red CRT,When it Shorts the screen will Go all Bright Red and shut Down,The Best fix Would Be to Replace the Defective CRT (GUN)
Dec 30, 2011 | Sony Televison & Video
My 32LD30UA LCD TV is 16 months old, when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.Help?
My HITACH 32LD30UA LCD TV when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.
Dec 12, 2010 | Hitachi 32LD8700 32 in. LCD Television
Screen image turns red after 15 minutes
Ur backlight video board it,dying.Micro processor have shorted,must change the backlight board.
Nov 24, 2009 | Polaroid FLM-3232 Television
Picture is red and black. hard to see the picture. sometimes, after 30 minutes or so the picture turns to normal.
Sound like a bad screen Capacitor screen voltage is low needs to be
replaced it should be a easy fix
Aug 11, 2009 | Apex Digital GB5108 51" Rear Projection...
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Magnavox TV
Turn Tv off by power point unplug even for 30 or 45 minutes then turn back on. that way the tv has time to reset back to normal
Sep 07, 2008 | Televison & Video
KP-51HW40 Sony 51" Fades to blue screen
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Aug 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Protron pltv-26
if your tv is up high try to lower it mine did the same thing but after i set it closer to the ground it stopped and hasnt done it since..
Dec 17, 2007 | Protron PLTV-32 Television
Problem with color
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
Jun 05, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Sony KP-65WV700 65" Rear Projection HDTV Logo
198 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
