Westclox 70026A LCD Atomic Digital Alarm Clock Logo
A
Anonymous Posted on Sep 28, 2014
How do you reset the time when the atomic signal is showing but not working?
I have a Sharp Atomic clock , model SPC373 and the time is incorrect. Everything else is ok, how do I correct the time?
To correct the time on your Sharp Atomic clock, you will need to reset the time zone. To do this, press and hold the "Time Zone" button for 3 seconds until the time zone flashes. Then, press the "Hour" and "Minute" buttons to adjust the time zone to the correct time zone. Once the time zone is set, press the "Time Zone" button again to save the settings. The clock should now be displaying the correct time.
Aug 13, 2022 • Home
The atomic clock did not reset to daylight savings time. How di I reset it?
Depending on which country you are in (the UK won't reset for a couple of weeks yet), your clock will automatically reset when it receives the adjusted time signal. If your clock is not receiving the signal, try moving it near a window and away from any electrical interference, or it is possible that your battery is getting low and has not got enough power to receive the signal.
Lacrossetechnology
Hi Susuan,
One of these methods below should get your device working properly. Good luck!
LaCorosse Tech Support email address.
The product information page
From the manual:
915MHz RECEPTION CHECK FOR OUTDOOR TEMPERATURE SENSOR
The atomic clock will receive the temperature data within 3 minutes. If the temperature data is not being received 3 minutes after setting up (the display shows "- - -"), then please check the following points:
1. The distance of the atomic clock or outdoor temperature sensor should be at least 6 feet (2meters) away from any interfering sources such as computer monitors or TV sets.
2. Avoid placing the receiver onto or in the immediate proximity of metal window frames.
3. Using other electrical products such as headphones or speakers operating on the same signal frequency (915MHz) may prevent correct signal transmission and reception.
4. Neighbors using electrical devices operating on the 915MHz signal frequency can also cause interference.
Note:
When the 915 MHz signal is received correctly, do not re-open the battery cover of either the outdoor temperature sensor or atomic clock, as the batteries may spring free from the contacts and force a false reset. Should this happen accidentally then reset all units (see Setting up above) otherwise transmission problems may occur.
The maximum transmission range is 330 feet (100 meters) from the outdoor temperature sensor to the atomic clock (in open space). However, this depends on the surrounding environment and interference levels. If no reception is possible despite the observation of these factors, all system units have to be reset (see Setting up).
Looses time after day light savings time
Clock shouldn't lose time if it is receiving time signal. Do you have the signal indicator showing?
If not suggest you take the batteries out and reset the clock, making sure that you do not set a time.
2helpful
Every atomic clock in my house shows a different time!
They all receive the same signal, but it sounds like you're in an area where the signal can't get through. Check to see if your clocks have an icon that indicates signal reception (most do). If your clocks cannot lock onto the signal you may need to place them outside for a few minutes every few months.
3helpful
Changing the time
you can go to http://www2.oregonscientific.com/assets/manuals2/bar338pa.pdf to see or print the user's manual.
If you don't want to get the manual, here's what you do to fix it. . . . .
*note: you need to do this anytime you change the batteries.
1) open the battery cover
2) on the left side you'll see 3 little buttons labeled a)zone, b)C/F c)reset
3) push the reset
4)push the zone button until your time zone is highlighted on the front display
5) look at the front display & if you see a blinking "radio signal" icon at upper left of time numerals
don't do anything else. The time, date, etc. will automatically synchronize your clock with the US Atomic Clock. This could take up to 10 minutes. As long as the "radio signal" icon is blinking, it's working on it. When the icon doesnt' blink, it's set. Cool, huh?
6) if the area you live in can't receive the signal from the Atomic Clock, instead of a blinking "radio signal", you'll see just a bare antennae. Since you probably set your clock manually, that's what it shows now before you do anything.
7) after you push reset & set the time zone do NOT touch any other buttons to set anything!!! (I know it's difficult to leave things alone, but just sit on your hands). Pushing the "clock" button or the up & down arrows will stop the radio signal & change to manual functions. Look at the signal icon mentioned in 5) and 6) above. If you only have the bare antennae icon. . . . . go ahead & set the time/date yourself. You have no signal.
Enjoy your clock!
debkresh
Casio WV58A-9AV Atomic Watch Signal Symbol
When the logo is not shown in the bottom corner, the watch hasn't got a signal yet. put your watch on a window sill, and hold the Forward buton until the watch says GET! Form there, the watch will either display ERROR, if it couldn't find a signal, or will have the latest and most accurate time. The watch is also probably set up for auto detect, which is best. To do auto detect, before going to bed, the watch will try to get a signal from 12 midnight, to 5 in the morning.
Top Westclox Audio Players & Recorders Experts
nexrad_chris
Ngoro
Are you a Westclox Audio Player and Recorder Expert? Answer questions, earn points and help others
