Hey friend, thank you for your post!
I see your oven lock light is flashing and the oven is not working on your Frigidaire range. Are you able to provide model number, with that information I can research any additional information for your range. You can locate the serial tag (which lists your model number) behind the bottom drawer of your range. Thank you for the post and I look forward to assisting you. -Matt
SOURCE: self cleaning oven will not start for cleaning door lock problem
hi alot of people have been having this same problem with either the door locking before clean cycle and not opening or it goes through clean cycle and then the door is stuck shut and wont open.
You could try this it sometimes works before you press start push the door shut and keep pressure on it i mean lean on the door so your pushing it shut further than it is now then whilst putting pressure on the door try pressing start button again if it then starts cleaning cycle keep pushing door for about a minute then gently let go of the door.
This should then allow it to go through clean cycle but remember when clean cycle has finished dont try opening the door strait away as you will then have the problem door stuck and wont open you need to let the oven cool down before the door will open.
If after pushing the door shut a bit further you still have problem then the only thing you can try is switching off at mains for 24 hours this should release the lock let me know how you get on ok
SOURCE: frigidaire oven door locked
SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND REPLACE IT WITH THE ONE PLUGGED IN.
SOURCE: Fridgdaire self cleaning latch
try holding in on the door latch plunger the one that turns the oven light off when you close the door then press start then cancel and inspect the door plunger for any damage
SOURCE: Frigidaire---oven door locks.
On my Frigidaire electric range with flat screen front controls, when the "Clean" control was accidentally pushed and the door locked, I could not unlock the door by cutting power, by running the clean mode for 30 seconds then pushing "Clear", or by hitting any button. What opened the door was holding down the "Clear" button for 30 seconds until the range started beeping and code "F11" read on the led. This worked. Good luck with yours.
SOURCE: Fault code f90, door lock light keeps flashing and then the oven beep continuosly.
PT NO 3148558 Kenmore
Why do I have a blinking oven light on the clock panel?
