Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Problem for Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
I AM UNABLE TO GET THE FUEL CAP TO SCREW DOWN
By lriley2003 on Jul 04, 2009
I AM UNABLE TO GET THE FUEL CAP TO SCREW DOWN TIGHT ENOUGH TO PREVENT LEAKING. REMOVING IT TAKES A SCREWDRIVER USED AS A LEVER OR A PAIR OF CHANNEL LOCKS.
WHY DID THE FUEL CAP SUDDENLY BECOME TOO TIGHT?
Best Solution
posted on Jul 04, 2009
Very Helpful)
dwc252
Rank: Master
Rating: 84%, 10 votes
Sounds like the cap has become cross threaded or has some sort of build up in the threads on the saw or on the cap. Try cleaning off all threads on saw and cap with a little two cycle oil on a rag, leaving a little oil film on the threads when you are done wiping them down. If that is not the case and does not fix the problem I recommend you take it to a repair shop and they can sell you a new cap for a couple of bucks then you can verify if the new cap is the solution. Good luck.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Poulan Wild Thing 2375 18" Gas
Questions and Unsolved Problems for Poulan Wild Thing 2375 18" Gas
Do you recommend Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin?
Answer
Answer
no spark for a craftsman 2100 watt generator
Answer
how to change the spline that holds the sprocket and clutch assembly together on a poulan wildcat... (More)
Answer
I need a manual for the Makita G650R Generator please
Answer
My Makita Generator, Starts but wont run for long. It appears there is a part missing on outlet from... (More)
Answer
mac 3200 saw will nit start even wuth starting fluid but does have spark
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Chain Saw Experts
Top Garden & Power Tool Repairmen
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
