Question about Sanyo 09KHS51 Ductless Mini Split Air Conditioner
No heat We had the mini split installed and have not needed the air conditioner yet. But now that I want the heat on, I can't get any. The indoor unit lights up and the fan comes on but only blows cold air. I have checked everything I dare to, and noticed that the outside unit doesn't seem to be running. I am reluctant to call the guy who installed it because he was not a happy guy to do it in the first place. But he was the builders choice. Any suggestions of things to check into myself?
  • kenda Dec 22, 2007
    I have a klimaire minisplit heat pump, just installed. I set the remote for heat pump. The vent slats orient downward when turned on. After about a 3 min delay the compressor and fan come on outside. The fan stays off inside. in the heat pump mode, no heat shows up in the coils inside. When I touch the compressor tubing, some of it is quite hot. Is there something that could be stopping the heat from going up the tube to the inside?
  • 288 Answers
From my experience, when a new heat pump unit doesn't switch over from one to another, its most often the thermostat isn't wired correctly. The reversing valve needs energized or the common isn't wired at the thermostat. As your installer was not a "happy" guy maybe he neglected to check this. Your best bet is to get your installation manual and the thermostat wiring guide, and check the connections. If you can read a schematic you may be able to figure it out. If this is a new construction, this should be covered under the warranty. Builder be damned Id make him fix it.
Posted on Nov 13, 2007
R22= 70-80psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Hope this helps
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more:
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
What could be causing one of the wall mount units to ice up on a 3 port mini split hp?
Icing is caused by one of two things.
1. The air coming in is too much and has a lot of water vapor in it.
2. The evaporator is too cold. This could be because of a low refrigerant charge
Jun 04, 2013 | Fujitsu ASU7RLF HFI Wall Mounted Mini...
Not blowing cold air tough there is an airflow, how can I repair it?
if no air come from indoor unit then indoor fan motor problem and if air come but not cool then check it gas from out door unit if gas present then change its compressor capacitor it will be ok
Jul 25, 2012 | LG LS-K2430HL Heat Cool Mini Split Air...
Hello We just installed a Sanyo KHS1271 mini-split
The condensate drain line was not properly installed. Make them pull the wall unit and correct the problem.
Be persistant until you are satisfied they have the problem corrected. Do not pay any additional money. If they do not correct the problem then report them online to the state board of heating and air. Fill out their requested complaint form and follow thru with a second complaint if you do not get total satisfaction from the contractor that installed the unit.
Hope this helps.
Sep 23, 2011 | Sanyo Split System Air Conditioner
My LG mini split want cut off. I can cut it off on the unit but it still runs wide open it will not cut off by the remote either. any help appreciated.
This sounds like a faulty thermostat (indoor unit), or a welded (shut) set of contacts in the condensing unit (outdoor unit)
Aug 09, 2011 | LG LS-K2430HL Heat Cool Mini Split Air...
I have two senville mini split 18000 and they both frost up with in 1 Hr. of use both have been pumped out and recharged
Dear Friend! Before recharging gas.did you check leak testing? If not, again you will same problem.
And some more reasons for frost up:
1. Indoor coil & air filter dust blocked-clean it. 2.Less rpm of indoor fan motor- replace capacitor or motor.
Thanks, it's helpful to you.
Jan 10, 2011 | LG LS-K1830CL Cool Mini Split Air...
Sanyo 09KHS51 Ductless Mini Split Air Conditioner Logo
305 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
