It wont burn anymore HELP????
SOURCE: Toshiba SD R2312
if you have indicated the correct model, then it is only capable of burning cd's, but reading cd's and dvd's
SOURCE: dvd not reading disc it just wrote
you might try + media also see if there is an option to finalize the disk.
SOURCE: wont burn dc or dvd
Have you tried installing the original software did it have one if NOT. Then go to google type LG DRIVE 16 HL-DT-ST DVDRRW GSA-4166B Software. See what google comes up with you will be surprised. The reason why its not burning as you say is because you are using a foreign software. I hate saying this but sometimes hardware can be sentimental like your wife/husband. Goodluck your prolem lies with software not hardware.
SOURCE: super multi dvd writer gsa-h55n
Well, since I received a solution from MAXTRIXKHAN, I just wanted to check back with NCIX.com, and here is a recap of what I did, and what they told me...
After a few tries, I had to contact LG Customer service.
I tried to burn to...
-Maxell CD-R, no problems,
-TDK DVD-RW, no problems,
-Verbatim DVD+R, Computer hangs.
Well, I bought this DVD-Writer to replace my old GSA-4167B, and LG customer service told me that this DVD-Writer does not support the Verbatim DVDs.
So, if you have plenty of Verbatim DVDs, you should forget about this writer.
Supported DVDs...
Maxell, Sony, TDK
Will have to send it back to NCIX
So beware
tiyo73
SOURCE: did not burn dvd
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD
Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving
your files in their native format than for creating standard DVDs that
can be played on regular DVD players. Regular (standard-definition) DVD players
can't play AVCHD, although many Blu-Ray players can. Unless you use a
Blu-Ray player that supports AVCHD playback, there are two solutions to
your problem:
1. If you want to keep your recordings high-def,
you can view them by playing them back with the DW-100, which must be
connected to your camcorder via the USB cable, then from your camcorder
to your TV via an HDMI cable.
2. If you want to have standard
DVDs that you can play on any DVD player, either import the files to
your computer and convert them to standard-definition using
video-editing software, then burn them to DVD with your computer's DVD
burner, or connect the analog output (component=better, composite=good)
to a stand-alone DVD recorder (i.e. not the DW-100).
I've used
the route of Vixia HF-10 camcorder > composite output > Panasonic
DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good
results when I've wanted to give videos to relatives who don't have
Blu-Ray players. You just have to make sure to set the camcorder 's
analog (composite) output to 480i so that it formats the picture in the
right aspect ratio, or else the 16:9 image will be squeezed to 4:3
instead of letterboxed.
Hope this helps. Good luck.
