I have a coil going bad on #1 cylinder and need to know
SOURCE: resetting maintainance light on a 2008 Scion xD
To reset your maintenance reminder system (even if the light hasn't
come on yet), you'll need to turn your key to on (but don't start!) and
make sure your odometer is on TRIP A. Then key off. Press and hold the
Odometer/Trip button. While holding down on the button, key the
ignition to on (Don't start the engine!) The display panel will count
down from "------" to "-"Continue pressing the button until the Trip A
is displayed. After this step, you are done.
Here can find one video about this procedure: Youtube vj7kK5i2tPc
I hope helps with this (remembe rated this help) Good luck.
SOURCE: were is the oil filter
2008 Scion xD oil filter is a cartridge (element only) type. It is located under a heavy, black plastic cap right next to the oil drain plug. To remove the cap, you will need a Toyota "Special Service Tool" or an Assenmacher Specialty Tools "TOY640" or similar cap wrench. Toyota is the only source for the oil filter element; make sure you get a new o-ring (should be in the box with the filter element) and a new drain plug gasket.
SOURCE: were do i find my oil filter on my 2008 scion xd
Scion XD's are of a choice few that uses a Drop in filter as opposed to screw on types.
The filter housing is on the passenger
side of the oil pan. The filter housing unscrews counter clockwise.
Just put an oil pan underneath to catch the little bit of oil that leaks
out. Pull the filter element out of the cartridge housing. Put the new
filter element into the housing, remove the old O-ring on the filter
housing, replace the O-ring on the filter element housing that is
provided with the "new" filter element. It's always a good idea to
lightly coat that new O-ring with motor oil before putting it on the
housing, providing a better seal. Then with the new O-ring and filter
element installed in the filter housing, just screw it on clockwise. It's really
not much different than the old style screw-on type filters. The only
place, so far, that sells the Xd element that I am aware of is Toyota.
They are about $6 a piece. On a difficulty scale of 1 -10, I would
declare this a (1.5). (1) being a regular screw-on type filter, and
(1.5) for the cartridge type filter on the Xd.
SOURCE: Oil Change light will not rest on a scion XD 2008
This should work.
Turn the ignition key to the OFF’ position with the odometer
reading shown. Turn the ignition key to the ‘ON’ position while
holding down the trip meter reset knob. Hold down knob for at least
5 seconds. The light goes off, and the display shows zero for 1
second and changes to the odometer reading. If the system fails to
restart, the light will remain on or keep flashing.
Good luck and thank you for using Fixya.
SOURCE: where is the 2008 scion
i tried to snap off the cover of the fuse box under the driverside dash located in the bottom left side of the front dash board. one side snapped off easily, but the other side was not budging. How do i undo the latch?
once i undo the latch is the cig fuse located there? if so what is the fuse number? i couldn't find the correct fuse it in the box located under the hood on the driver side.
Please help :(
