Question about Hitachi TravelStar DK23FB (08K1427) 40 GB Hard Drive
Connect dk23fb-40 ext in front usb
I want to buy just electronic for this hdd. Where to buy? Tnx
  • 99 Answers
Re: connect dk23fb-40 ext in front usb
You cannot usually by just the electronics. I would check places like ebay or ask Hitachi about it. The other way would be if you could find someone throwing out one of the drives where something else is bad.
Posted on Nov 14, 2007
0 characters
3 Points
My Computer doesn't recognize my simpletech 2TB ext HDD
check USB connection i think you have 2.0 usb connector and 2 TB HDD required 3.0 USB port so check it first
Sep 28, 2011 | Hard Drives
My computer don't see mt toshiba 500 GB external disk. I had Win XP with SP3 and my external disk is connected to a USB hub with 8 ports. I had a pen connected to that hub and the computer see it. But...
Your USB hub cannot provide enough power for your external hdd, you can try to plug it in directly to any free USB port for the mean time to check if its detected or not, if it has a power button ( which is not normal for regular USB powered EXT HDD) make sure that it is on, if its still not working try to use a different cable, a known good cable or plug it in to a different computer to check if its your USB port, or the usb cable or the ext hdd that is causing the issue
Hope this help.
Jul 10, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
Hi. My computer says I ejected my WD My Passport external drive but it was not properly ejected. How can I fix this. I need all my thesis files but computer can read the external drive! Help please!
Try to test your WD Ext HDD to a different computer and check if you will get the same problem.
If the same problem persist try to use a different cable for your WD Ext HDD.
If still fails kindly ask the store where you bought the WD Ext HDD on how to retrieve your files and have WD EXT HDD replaced?
If your WD Ext HDD works to a different computer then update the BIOS and Chipset of the computer where your WD Ext HDD connected previously.
Hope this helps.
May 29, 2011 | Hard Drives
Ext hdd wd3200me does not detect on my com.. Its using intergrated usb controller method..any suggestions..
Update the drivers for the communication. You can download from the manufacture's website of the EXT hdd.
They are usually under the download or support tab.
Just down the drivers, double-click on the file to install them into your pc, then restart pc then connect.
Jun 27, 2010 | Western Digital Elements powered by WD 320...
Ilooked up the spec on my computer from dell (that
u need a SATA (serial ATA) drive, buy a SATA drive and its compatible with most of the computers today.
u can read about SATA drive by clicking this link i am giving:
plz do not forget to vote and click yes if i solved your problem,thank u! :)
Sep 05, 2009 | Hitachi TravelStar DK23FB (08K1427) 40 GB...
Hitachi DK23FB-40 not detected
the external hard drive casing may need a driver for some operating systems
and then the unit must be in the on postion
Jul 19, 2009 | Hitachi TravelStar DK23FB (08K1427) 40 GB...
Ext.hdd can't be detected..
When you have the drive connected,go to your control panel,open up Administrative tools,Computer Management,Disk Management.See if drive is there.If it is, right click in drive space ,assign a drive letter.
If not,scan for new hardware.
You could also look at your usb port handler in your device manager.Update your usb controller,usb handler
Jan 18, 2008 | Hard Drives
Hitachi TravelStar DK23FB (08K1427) 40 GB Hard Drive Logo
111 people viewed this question
Top Hitachi Hard Drives Experts
John mullen
D. E. Hev
Are you a Hitachi Hard Drive Expert? Answer questions, earn points and help others
