SOURCE: 1993 Isuzu Trooper auto locking hubs not engaging
Just have your auto - locking hub cleaned and use your 4wd more often, it get stock usually for non usage. dont use grease after cleaning, use oil or thick silicone oil.
SOURCE: isuzu rodeo 97, A/C no work if on number 3 only
try checking out your blower speed control resistors. follow your power wire from blower to the resistors, to locat, should be in duct in front of blower for cooling. I hope this helps, if the resistors pack is good only think else is a bad switch
SOURCE: where is air cabin filter located on 99 isuzu rodeo?
its usually behind the glove compartment in the blower box. you will have to pull the GB door down all the way to access it
SOURCE: Transmission fluids
If you have the 4 speed 4L30-E..........9.2 quarts (automatic)
And, if you have a manual:
Manual Transmission, W/ BW 5-SPD..........4.4 pints
Manual Transmission, W/O BW 5-SPD..........6.3 pints
Type of fluid is dextron or mercon III, you have to pump it in from the bottom.
Please don't forget to rate!!!!
