My Dometic 2852 will not cool in gas mode. The igniter continues to click despite a small blue flame in the burner. I have take the gas valve out and cleaned it and removed the orifice and cleaned it as well. I also checked to see if I have sufficient gas flow through the hose and the solenoid is opening when the fridge is turned on/during start up. Help please...
If the igniter continues to click, that means that the control board is not sensing the flame through the igniter. You need to clean the igniter tip to make sure that there is not a build up of soot or corrosion. The tip of the igniter should be approximately 1/8" from the flame tube. The only way to determine "sufficient" gas flow would be to perform a manometer test to ensure that you have 10" - 14" water column. I would start with cleaning and adjusting the igniter so that it will not continue to try to ignite. If that does not stop the igniter from striking then you will need to replace the igniter. If it continues after you install a new igniter then you are more than likely experiencing board failure.
SOURCE: FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
SOURCE: Dometic rm 2652 fridge works on a/c. i get a check
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
SOURCE: Dometic RM2562 - No Flame
use a set of needle nose pliers & disconnect the igniter wire the module should start clicking if it does not click check the wires to the board clean them good & reconnect if the module still wont start clicking your board is bad if it does click the igniter adjustment off stick a nickle between the igniter & burner the gap should be the size of the nickle 3/16"
SOURCE: Dometic rv fridge runs fine on elec, lights on gas
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
SOURCE: 98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
