How do you close a very old peg per ego Milano stroller?
SOURCE: I cannot close milano stroller
I read the answers written here and I can see why some people are still confused. So I will try to break it down into steps:
1. With your foot press down on the lever numbered 1 at the bottom of the stroller. This lever holds in place.
2. With your foot press down on the the lever numbered 2 at the bottom of the stroller. Hold this lever down with your foot because it does not lock in like lever numbered 1.
3. While your foot is still pressed on lever number 2, hold the handle bar with both hands and **** it forward. This step is rather tricky. So think of it as punching both hands forward horizontally while holding the handle bars.
At this point the stroller will come apart and fold. Now if you see that the stroller is stuck in position and does not fold or comes apart only with a lot of force then you have to oil the joints. Use WD-40 and spray it on the joints on the side of the stroller located right below where it say "PegPerego" on the body of stroller. That is where the joint where the stroller folds is located.
Hope this helps.
