N TO D only or with.
P to R or N to R harsh, or with
or
all upshifts in drive to all 4gears harsh????????
when it changing gear, means automatic shifts by IT?
silverado, 1500 or 2500? we sure can't guess. , NO VIN told. or RPO list showing M-xx code for trans there.
which engine it is. trans match engine for max tongue.
4.3, 4.8 , 5.4L
automatic trans, (mine was stick) 4L60E -RPO M30
4L60E<<< is my wild wide guess and is 5.4L
- check levels yet per the operators guide,not ever done like and engine or axle.
- scan it is next it will have DTC errors and with the we see why.
- bad U-joint or TC FLEX PLATE bolts missing, OR LOSE.
- jammed accumulator, (this is shock absorber for just that act)
- bad pump regulator (too high PSI)
- wrong ATF FLUID OR LAME ADDTIVES LUCAS ADDED,
- BAD STICKING CLUTCH PACKS.
- EPC bad or its filter clogged. electronic pressure control
- LOTS MORE AS LOTS THERE, even bad pump.or bad TC
https://www.transmissiondigest.com/4l60e-harsh-1-2-shift/
wild guess me all that, not told all modes the trans is harsh..
