Question about Altec Lansing ADA 885 Computer Speakers
No sound Hello Fixya,I have altec lansing ADA 885 speakers that have stopped working. The display lights up on the control speaker but no 'prologic' or 'dolby' display etc. It is not a soundcard problem as i have attached other speakers and they work ok.Grateful for any help,thanks,John in Dublin ,Ireland.
  • 3 more comments
  • Johnjoseph64 Nov 12, 2007
    thanks willydjm for your help, unfortunately the solution did not work.
    best regards, John.
  • wesouth Dec 17, 2007
    i have the same problem. for several years the ada885 worked great and then one day the display on the right speaker that controls the whole system was lit up and flickering when I pressed any button controls. my guess is that it is the control board in the speaker that is the problem. If anyone knows how to fix these electronics for the ada885 please let me know. Thanks
  • Sodrak Dec 20, 2007
    This is just great. Today my wife told me we have no sound sure enough, same problem as described above.
    I have power (fuse checked good) have power light on subwoofer but no display on right speaker. No sound even using the diagnostic button.
    I have a pair of Altec Lansing ACS40's connected now and they work fine so I know sound card is good.
    Anyone know where a manual of ada885 can be found?
  • kong 69 Mar 31, 2008
    I have no sound from my ADA 885 speakers. The display is flashing and I can't change modes by pressing the mode control button or the remote control. I have checked the fuse and everything checks out fine.
  • Sam Oct 20, 2008
    Yep, Same here. We've all found no solutions. I took the speakers apart and am going to check for bad capacitors. I saw on another forum that this guy was going to replace them on the power board and see if it worked. No replies yet. I'll keep mine posted too.
  • 3 Answers
I FOUND THE SOLUTION (at least for the led text blinking in and out with no sound).
It's the Altec's Circuit board!!!. If you take it all apart (not too hard) and within the circuit board where you plug in all your connectors (i.e. speakers, computer jack, etc.) , take it all out. Once you open the casing, you will find a couple connectors with wires (yellow, blue, green) plugged onto the board. Unplug both connectors on the board. (Careful!, one of the connectors, smaller one, are glued onto the board, but what I did was cut it off using a blade (box cutter)). After you take it apart, there will be two pieces of circuit board facing each other, one top (small), one bottom (big) (where all your speakers plug in to). On the top board (smaller one) wipe up the "rust" looking stuff on the back of the PCB board with little damp cloth. After you get most of it off, it will work again.
(How you know if it's the top of bottom is how the capacitors are working.
WOO HOO!!! I love these speakers!!!
Also, if your bass is weak, I found on another forum that it's the capacitors. Get those replaced at a local electronic repair shop. Find them on Google maps.
Please let me know if this works for everyone. THANKS!
Posted on Oct 24, 2008
  • TableTopJoe Oct 17, 2010
    Much much thanks! I somehow lost two screws, but my speakers are now working wonderfully. This is a very high quality speaker set, despite being 10 years old. I couldn't be bothered to set up and config a new set that will probably underperform. Thank you, Thank you.
Guytocool: It worked. I already had it apart, thinking it had to be the connector. I'd replaced the cable, after it started shorting in and out before it died completely, with no help. But I read your post, cut that little bit of boxcutter plastic, wiped it all down with a cloth and VOILA! music. Now I get to reassemble it all...not too tough if the screws are still where they should be...
Posted on Dec 11, 2008
Thanks Fixya for getting back to me. My speakers are working now thanks to a local genius who
runs a small outlet here in Dublin Ireland. I agree these speakers are the best and I am very happy
to have them working againl. Regards, John.
  • 29 Answers
Check the connector that the speaker with the control is plugged in with, make sure that where it is connected to the sub woofer that in the connector , all of the pins are there, and that none are broken, also cdheck the sound cable, try switching it out for another : )
Posted on Nov 11, 2007
Dp/n 08506p drivers
I have ALTEC LANSING DP/N 08506P speakers om my Windows 7 PC. The left speaker works fine but no sound from the right speaker. I "think" this is a rather recent event. Can you help?
May 24, 2014 | Altec Lansing ADA 885 Computer Speakers
Cable setup for Altec Lansing ADA885 system needed
Try using the internet to get the information you need
Mar 01, 2013 | Altec Lansing ADA 885 Computer Speakers
Hello, I have an Altes lansing ad-885 system and I have lost the cable that connects it to the pc, Where can I purchase a replacement. Thanks,
Altec Lansing ADA 885 connects with an SPDIF cable. Something like this should do the trick for you:
Dec 22, 2010 | Altec Lansing ADA 885 Computer Speakers
No sound out of speakers diagnostic button does not produce test tone,and right main speaker control flashes PROLOGIC. I have heard the motorboat sound coming from the subwoofer,but no sound now,green...
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
Dec 18, 2010 | Altec Lansing ADA 885 Computer Speakers
Broken pin on wire
I am not familiar with this model ... I must ask ... Are these standard electronic plugs? RCA, Mini or micro phone? Mon or Stereo?
Two souces that pop into mind are Altec Lansing or Radio Shack.
Thanks for your interest in
May 14, 2010 | Altec Lansing ADA 885 Computer Speakers
Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
Lights on Altec Lansing display flashing after power outage and have no sound,check drivers and they are active and okay,but unistalled and reinstalled just the same,no results;also replaced fuse on...
I had the same problem. It ended up being a short in one of the wires in the control board. It was actually pretty easy to fix once I located all the screws to take apart the speaker where the board is housed...
Nov 28, 2009 | Altec Lansing ADA 885 Computer Speakers
Thanks for posting direct. As you posted, the Sony XBR has only left & right (white/red) outputs whereas your Altec ADA has multiple INputs. This leaves us with no other option but to used just the green INput of the Altec as the black and the S/PDIF has nowhere to be connected to in the Sony.
You would need to use a phone stereo to RCA cable/connector as shown below. Additionally, you would have to set up your speakers as suggested here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 11, 2008 | Altec Lansing ADA 885 Computer Speakers
Altec Lansing ADA 885 Computer Speakers Logo
623 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
