SOURCE: Chrysler voyager stereo unlock code
take it to the dealership with the vin number and serial code from the unit they can give you the code
erik
SOURCE: radio code
According to the dealership, Chrysler doesn't use lock code on their radios. The dealer advises to buy a new radio.
SOURCE: door locks
Daughter had same problem on '05 T&C. Neighborhood mechanic searched Internet and found 80-90 others with same problem right around 40,000 miles. Free solution was to pull yellow 20A IOD fuse in right front corner of fuse box under hood, wait 10 seconds, then reinsert fuse. Should solve problem as long as you don't lock doors with FOB. You can unlock doors with FOB, but apparently locking with FOB causes the problem.
Permanent solution is to have dealer reprogram computer for around $50 which is what my daughter chose to do because of inconvenience of not being able to lock doors with FOB when getting baby/carseat out of vehicle.
SOURCE: Central locking not working, Chrysler Voyager Limited 2005
hi this works on most voyagers disconect the possative terminal on the battery for ten minites excactly then reconnect and happy days your voyager centrol locking should work ok good luck
SOURCE: The power lock (driver's side sliding door) on our
Take a look at end of door where latch is & post where the 2 meet when closed. Look for round metal button/contacts, about 1/2" in diameter. If you look close, they should line up to make contact with each other when door is closed. Take some fine steel wool (preferred) or fine sandpaper and scuff them up until you see metal is clean on both surfaces. Now try it, and let me know what happens.
