Home | Danby | DDR586R Dehumidifier - 58 Pints Dehumidifier | Bucket fills instead of ...
Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
Problem for Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
Bucket fills instead of going down the drain
By harpsmarx on Jul 04, 2009
worked fine going down drain before. checked direct hose into floor drain and clear. after a few years now bucket starts filling even with direct drain to floor ?? how do i fix?
Solution #1
posted on Jul 04, 2009
Not Rated)
dtlong887
Rank: Guru
Rating: 90%, 44 votes
You may have an unintentional trap in the line (an up and down up and down. Hose has to lay flat on floor to drain.
Was this helpful?
Yes
No
Popular Solutions for Danby DDR586R Dehumidifier -
Questions and Unsolved Problems for Danby DDR586R Dehumidifier -
Do you recommend Danby DDR586R Dehumidifier - 58 Pints Dehumidifier?
Answer
Answer
i recently had a brown-out and have had damage to a number of appliances. this occurrance blew the... (More)
Answer
how could i use my ddr586r dehumidifier because i lost my instraction
Answer
Danby Dehumidifier Model # DDR586R Serial # 6763858666 (only 28 months old) - Does not collect water... (More)
Answer
tank does not fill with water at all. How to adjust humidty levels? what does the temp grad mean?... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby DDR586R Dehumidifier -...:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
