My Lakewood stand fan broke right in two. The whole fan just bent over and snapped off of the pole. I need to get a new aluminum (looking) pole section for the base. Where can I get one?
Is it still under warranty, or does your store or credit card carry/extend the warranty?
See if the manufacturer has parts.
What diameter, inside and outside? Might a patio umbrella stand work? I often see those at the curb on trash day - if the metal scrappers don't get them first!
I'm still not sure how it would have broken in two. Most aluminum bends and might get kinked, but not break on its own.
SOURCE: to repair 18" lakewood stand fan mod.#HV-18-p
unplug the fan!
1 remove the six screws that hold the front grille on.
2 use an allen wrench to loosen the screw that secures the fan blade assembly to the motor shaft. (screw is between the blades and the motor and it is on tight, make sure that you do not bend the fan blades, this would cause balance problems)
3 remove blade
4 you will now have access to the screws that hold the motor cover in place.
5. when reassembling make sure that the strain relief (or knot in the cord on some models) is inside the motor cover, and that wires are not being pinched.
6. Good luck
