Question about Plumbing
Irrigation system problem
My irrigation system will not work. The well has a new pump and supplies adequate pressure to the house unless an irrigation line is turned on. Each head only trickles a little and the pressure in my house drops to nothing. I don't suspect a leak because the well does not run unless a sprinkler line is running. The well pressure stays up in the 50 PSI range during this time but will not activate any of the heads. I cannot even get the sprinkler system to work manually. I do have one line that works and when the sprinklers are running, the pressure in the house is still good. It only dies down when a line is turned on but not putting out any water. Could this be a faulty gate valve that maybe blocking adequate flow of water to the sprinklers a creating some type of back pressure that stops the flow of water to the house? If anyone has seen this type of problem and has an idea I would appreciate hearing about it. Thanks.
  • 832 Answers
How big is your pump? How much HP rating? It could be a case of blocked water line. Just check your pipe lines and the gate valve for blockage. Just your e-mail
for your comments.
Posted on Oct 28, 2009
I have a cracked iron housing on 313834 2hp irrigation pump. Where can I get a replacement part?
quality irrigation and pump supply retailers in your areas
any agricultural retailers will be able to get what you are after
try e-bay or gumtree as well
Feb 26, 2017 | Plumbing
Installing an irrigation system of a well with a 2 horse pump and two 110 gallon water tanks..had a partial irrigation system installed and running since october of last year and it was working fine..now...
Shut off everything.
shut off tank.
open hose bib directly supplied by well.
do math.
use stopwatch and 5 gal bucket and google to find out your GPM.
compare it with prior year or well driller info.
also talk to your neighbor and find out his new GPM
Jan 14, 2018 | Plumbing
Our auto irrigation system wouldn't turn off. We found the Davey XJ70 pressure pump was leaking so replaced the leaking pipe. Now the watering g system won't start. What do we do?
Hi Geralidine
Sounds like your pump is "air bound"...meaning that the impeller housing of the pump is full of air, and it cannot pump water.
Try bleeding the air out of the pump and put a positive pressure (garden hose pressure) and make sure that you shut the airbleed valve off after you start to pump.
Please take time to rate me
Bud
Mar 31, 2013 | Plumbing
Pressure switch no longer making contact
First try to clean the contact points, maybe it's help
Mar 26, 2013 | Flotec Pressure Switch 40/60 TC2153
The well pump is running, but no water is supplied to thr irrigation lines. once I put water in the pump housing by removing the pump guage the pump pumps water through the irrigation lines. when it shuts...
Sounds like you have an air leak. First check your fittings, next carefully run water over the pump seals (avoid getting water on the motor or you'll hurt yourself and the pump if not worse) the pump will prime if the leaking seal is covered with water. Take your time and be careful and it should only be a matter of a loose fitting or simple seal swap.
Mar 08, 2011 | Sta Rite Ds3hf 1.50 Hp Self Priming...
I have a lake house with irrigation system drawing water from the lake. The pump works. But there is a second primer pump that I do not know how to turn it on or how it supposed to work.
I used to take care of a system like that in the basement of a ten story college dorm. There was a big pump and a little pump. The purpose of the little pump is to maintain pressure when there is no usage of water. Then when a big demand comes, the big pump kicks in. I had problems with the
big pump getting hot, because the controls didn't work right. I unhooked all the controls and strapped a heat sensing aquastat box to the discharge pipe. When the water got hot, this state
would open a tiny little solinoid valve and dump enough water down the floor drain to keep the
pump cool.
Nov 04, 2010 | Plumbing
I have a 1/2 hp pump which I use to pump lake water to my irrigation system. The pump takes too long to turn on when the spicket is opened and sometimes too long to shut off when the water spicket is...
when using the spicket you use less flow than your irrigation system so a delay in the pump coming on is normal...otherwise if you are having the same problem when the irrigation is running..a pressure switch adjustment may be necessary...please follow the manufacturer instructions for your pressure switch.
Mar 31, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
REPLACING A NEW GASKET ON AN AO SMITH 1HP PUMP
NOOOOO!!!!! NEVER put any kind of cement on a gasket! It will RUIN IT!!!!
Tim @ International Sprinkler Supply - www.internationalsprinkler.com
Mar 26, 2009 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Pump runs continuously with not water
replace the pressure guage.
prime the pump by pouring in water in the impeller basket area and replace lid-try running pump again
Mar 22, 2009 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Plumbing Logo
332 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
