Question about Sony SLV-D350P DVD Player/VCR
Codes hello,   I'm looking for  codes to my sony dvd vcr combo   slv-D350P for a papasonic tv... thank you so much if you can help. chi
06, 19 are the listed codes in the book
Posted on Feb 18, 2008
Sony slv-350p dvd combo disc tray wont open
Might be to a broken loading belt, or damaged loading gear wheels. Check it. If gear wheel is faulty, it will be best to repalce the disc loading mechanism.
May 14, 2012 | Sony SLV-D350P DVD Player/VCR
Black and white dvd playback
because on line out video mode are in NTSC and not in PAL how must be to play in color mode
Feb 09, 2012 | Sony SLV-D350P DVD Player/VCR
SLV-D350P DVD Player / VCR Combo remote codes
You may have to use a universal remote control.
Dec 21, 2017 | Sony SLV-D350P DVD Player/VCR
There is no sound on my Sony SLV-D350P DVD Player / VCR Combo. The only section that works great is the VCR, but the DVD player sound just went out for some reason. I've changed the RCA cables, and...
Hi, As long as you have the picture it means that DVD's Laser Eye is Ok.. Pls Check your connections to make sure the audio and video cables of both VCR and DVD are properly hooked up to the television. Color coded cables should be matched with the jacks of equal color. Yellow corresponds to video while red and white are both audio.
Ensure the DVD is in standby mode if you are not getting picture from the VCR. The DVD cannot be running at the same time as the VCR is playing when you want to see the VCR picture.
Connections with combo units are often inconvenient, forcing you to use separate video hookups for each section (DVD, VCR), a problem for older TVs. This player has it figured out: a single RF or composite-video connection to a television will display either the DVD or the VCR signal, depending on which format you're viewing. If you want to view DVDs in S-video or in component-video (either interlaced or progressive-scan), you will need to use two inputs. though: any component- or S-video-equipped TV will offer sufficient inputs for both of the SLV-D350P's formats.
It's a different arrangement for audio: you can listen through a single set of stereo analog-audio cables for each component or--if you want to enjoy DVDs in discrete 5.1-channel surround sound--you can send the DVD's audio to a compatible audio/video receiver and a multichannel speaker system through a digital-audio interconnect (either optical or coaxial,). The unit also comes with an RF cable that will transmit DVD/VHS audio and video to your TV.
In conclusion,for a best tech solution I prpose you to connect DVD audio directly to your Stereo and listen as separate audio source.while Video goes to TV as usual. Hope this helps! if you need more help pls contact me..Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Jul 02, 2011 | Sony SLV-D350P DVD Player/VCR
I lost the remote control for the Sony SLV-D350P. Where can I get another one and how much is it?
Required Remote Control is available in Sony Accessories Store for $30 under following part number..
Dec 18, 2009 | Sony SLV-D350P DVD Player/VCR
Sony SLV-D350P DVD/VHS Combo
No, most DVD players sold in regular store are for R1 only, you need to look online for multiregion player.
Nov 01, 2009 | Sony SLV-D350P DVD Player/VCR
Sony SLV-350P stopped working
q marca de control puedo usar, porq el original no lo tengo
Oct 11, 2009 | Sony SLV-D350P DVD Player/VCR
Code for sony dvd combo slv-d350p
I found this on a forum on line but it doesn't look promising. One person said this worked and one other said it didn't - only two entries though.
1)No disc & tray closed
2)Once the "Insert disk" message in the top-left side of the screen appears, press (in the remote) the Subtitle key and continue with 29334 in sequence.
3)A number(1 in my case)appears in the top-left side of the screen. I believe that this number represents the region code of your DVD equip.
4)Change the number by typing number 0.
5)To save press the "open/close" key and then Enter (small one at the top. Not the big one at the bottom!!)
6)Now check if it works.
NOTE: Other way to check if the change was successful, is to repeat steps 1 to 2. You should then see a 0 in top-left side of the screen.
Aug 22, 2008 | Sony SLV-D350P DVD Player/VCR
Sony SLV-D350P DVD Player/VCR Logo
170 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
