Question about Yamaha DSP-A1 Receiver
Left and right speakers has no sound?
Other speakes are ok and main left and right speakers has no sound?
  • Richard Tirado May 11, 2010
    Have you tried setting the unit to broadcast in Dolby digital or any other format that would utilize all of the speakers?
  • Anonymous Mar 24, 2014
    no sound on right door speaks
Just got my second dsp-a1. Heres the deal, if you have already checked all connections and have the correct source selected, but yet still dont get any sound from the MAINS left and right, heres what to do. Make sure you have proper bypass connectors in the rear where it says main left right. My new receiver came with the 2 bypass pointing up/down. Change them to the horizontal position. Make sense? They should look like two minus signs on the back of the receiver not two II , but rather = . Hope this helps, cause it saved me from what i thought was a blown main channel!!!!!!!!!!!!!!
Posted on Dec 04, 2009
    President:
  • Yamaha Master
  • 1,114 Answers
On the front of the receiver there is a small button for speakers "A" & "B" make sure "A" is lit up on the display. If still inop, post a comment and I will help some more
Posted on Jul 04, 2009
Question about Peavey Escort 3000 300 watt portable PA, both right and left mains work fine, but the right speaker has distortion sound. Even if I change speakers the right out speaker circuit is dist
sounds like an internal connection problem. open access panel and check the solder connection is not broken or loose. Be sure the metal mesh jacket is not touching the lead wire as that would cause a scratchy noise and feedback, or maybe near the internal cable causing feedback
Aug 06, 2014 | Peavey Escort 3000 300 Watt Portable PA...
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Lost sound in left channel?
I presume you are playing a stereo cd. Plug some other device, like headphones in to see if the computer is putting out stereo. Use the same plug as the speaker system is plugged into.
I presume you have swapped the speakers to test them.
If the speakers work, and the headphones work, it's the amp.
Nov 26, 2013 | Klipsch Promedia 2.1 Thx Computer Speaker...
Cannot get sound is there a switch to put sound on
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Aug 12, 2010 | Logitech Quickcam Chat Webcam
Since installing Microsoft Lifecam VX3000, I have no sound on my computer or on the Lifecam
check your audio out
TEST SPEAKERS
Restart computer
Aug 06, 2010 | Microsoft LifeCam VX-3000 Web Camera
Unable to connect surround sound with a stero player
There is a obvious difficulty here. If you have a stereo receiver then it can't produce surround sound. You must have a surround sound receiver to present true surround sound. If you already do have that then on the back of your Phillips set there are audio outputs. The left and right audio out will be decoded in your surround sound receiver and they will automatically play from your speakers. You should have seven speakers, center channel, left and right front speakers, left and right rear speakers and left and right mid or side speakers. A sub-woofer would be nice too. Best bet is to speak with the store you purchased the set from. They will have that information.
Zashiban
Jun 23, 2010 | Philips Televison & Video
Audio
Set the mic as default
Plug in the webcam
TEST SPEAKERS
Restart computer
May 30, 2010 | Logitech Quickcam Chat Webcam
There is no sound
Make sure you have your webcam mic set as default - especially if you have a laptop with a built in mic
TEST SPEAKERS
Restart computer
Apr 20, 2010 | Veo Velocity Connect Webcam
I can't record video with sounds using that A4tech
Make sure your mic is set as default - especially if you have a laptop that already has a built in mic
TEST SPEAKERS
In lower dropbox display "Use this device enable" click OK
Restart computer
Feb 12, 2010 | A4tech PK-635 Webcam
My microphone isn't working, there's no sound
Sound set up
Laptop x Vista x webcam mic x Yahoo messenger
TEST SPEAKERS
The speaker icon (checked as working) and volume level graph should be visible
Set required mic as default - click on mic font to highlight and click "Properties"
Click "Levels" tab and set slider to 100% (adjust to suit later)
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Sep 23, 2009 | Logitech Computers & Internet
Yamaha DSP-A1 Receiver Logo
373 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
