Question about Pentair MINIMAX NT TSI IGNITER
Heayrt won't fire e4 can't hear fan runnung
Heater won't fire e4 can't hear fan runnung
  • 83 Answers
I am not sure if you have gotten this issue corrected, or not, but the first thing I would try to do is to reset the heater computer system. This sometimes corrects and EO4 error code.
What you will do is open the right hand side door and find the POWER toggle switch, turn that off. Then find the CIRCUIT BREAKER for the heater and turn that off as well, then wait about 15 to 20 minutes. After waiting, you will turn the CIRCUIT BREAKER on first, then the heater. Try and start the heater up.
If the EO4 code comes back, there may be an issue with the heater. If the code does not come back and the heater starts, then the error code was what I call a "computer hic-cup".
Posted on Jul 09, 2009
The hot tub Hester will not light up pilot but does turn on and bow cold air
Glenn,
Many things could be wrong. First off, the exhaust fan turns always goes on when you turn on(up) the thermostat. It does that to suck out any residual gas in the combustion chamber. After about 10 seconds you should hear a click which is the gas valve opening to let the gas into the chamber. You should also hear a series of clicks for about 10 sec, which is the electronic ignition firing. If you hear the clicking of the ignition, but do not smell gas from the exhaust, then the gas feed is being blocked. If you don\'t hear the ignition clicking then the computer board is detecting a fault condition by one of its sensors: over-temp, water flow, exhaust fan . These are all in series and if one doesn\'t pass then the ignition won\'t fire.
Jun 08, 2013 | Pool & Spa
My heil heater is not firing up
take the hose off the exhaust fan assemby and suck on the end and you should hear it click try sticking a paper clip or something like in the hole where the hose coonnect on the exhaust hosing sometimes some junk just gathers there
Jan 18, 2013 | Honeywell Furnace Air Pressure Switch...
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
The heat is working but it won't tumble
tilt it back and see if the belt broke. do you hear the motor runnung?
Dec 31, 2011 | Dryers
Electrical - won't start. Hooked up fan to heater, smoke came out from under the hood, car won't start. Lights work, any key related electrical functions won't work
Your fan or heater likely shorted out and burned up, causing your one of the main fuses to blow due to the spike in current. You will need to determine what burnt up and replace it before replacing the fuse, or you may create a fire hazard or cause further equipment damage. Also double check any changes to wiring to make sure that everything is hooked up properly.
Nov 01, 2011 | 1991 Chevrolet Cavalier
Hi, Vulcan " burwood " gas space heater.I have
As long as the burner works it is unlikly that the thermostat is your problem. It is more likly the fan limit switch needs replaced.Unfortunatly I am having no luck finding a wiring diagram for this model so I can't tell you where it is at,but I think that's the problem. Thank you. Sorry I'm not more help
May 19, 2011 | Heating & Cooling
Heater fan doesn't stop runnung
check the blower motor relay, it may be bad.
May 23, 2010 | 2003 Buick LeSabre
DAYTON 210,000 BTU OIL-FIRED HEATER WON T LIT UP
You write "FUEL SPRAYING AND FAN WAS WORKING"
If the fan was working, but the fan is not working now after replacing the whole kit, then something was installed incorrectly during the installation, possibly the rotor gap or rotor thickness is not correct or vane/vanes installed 90 degrees off.
Dec 08, 2008 | Dayton E50 Heater
Pentair MINIMAX NT TSI IGNITER Logo
273 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
