Question about Dewalt 3700 Pressure Washer
Nozzle/wand leak on DP 3900
THe fitting on the wand that holds the nozzles for a new DP3900 leaks catestophically when the spray gun is activated. Replaced the wand and the leak is just as bad. How do I fix this problem
  • 174 Answers
It sure sounds like the gun is leaking and not the wand. If you have a repair service near you I am sure they wouldn't mind testing this for you.
Posted on Jul 04, 2009
The turbo wand and nozzle connection on my Pressure washer Model 580.752070 How to restore seal between Wand and nozzle? Please point me in the right direction to resolve this problem
the seal is normally a "O" ring that is available from a good hardware shop or bearing supply shop
basically the same set up as your garden hose "O" ring but with a pressure wand there is a thread nut to hold the bits together.
If it is not that then the threaded section of the connection in the wand or hose mat be loose or broken at the thread
Jun 12, 2015 | Garden
Pressure wand is leaking at the out let end, and pump has a small surge when setting at a idle
Sounds like water is leaking past the shutoff valve on the wand. Check your owners manual parts diagram to see if there is a washer or o-ring to replace.
Apr 16, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
Was sitting around for a couple months now water is not coming out of the gun
You may have a clogged spray nozzle. Remove the wand from the end of the gun and see if water sprays out.
what is your model #
Jan 20, 2014 | Simpson Garden
Generac 6hp pressure washer starts and runs fine, no real leaks, but it never builds up pressure.
after making the water connections, be sure to hold the trigger open on the wand for a couple of minutes before starting. All the air must be removed from the system before it can create pressure.
Aug 28, 2013 | Briggs & Stratton Pressure Washer...
Leaking air behind the trigger
If you take the gun apart you will see a small o-ring on the trigger side that needs replacement and possibly the spring on the media adjuster side as well
Feb 18, 2013 | ANEST IWATA IWA5810 LS400-1302 Spray Gun...
Siphon tube on cup gun blows into the cup
Other than a missing or deformed gasket ring around the nozzle assembly, there might be a gun casting leak from the air passages to the fluid passages. Hope this helps!
Apr 02, 2010 | Binks SPRAY GUNS & OUTFITS
I have binks model 21 automatic guns on my striper i installed rebuid kits when testing with water the guns drip water from liquid nozzle but not from needle it seats properly is this normal and will not...
If it is leaking fluid from the holes in the nozzle then the tip is not making good contact with the seat, the seat of the nozzle could also be dinged, or the tip / gun gasket might be bad. If the water is coming from the needle / nozzle seat, the needle or inside seating area of the nozzle could be nicked.
Nov 25, 2009 | Binks Air Tools & Compressors
Immediate pressure loss
your dip tube inside the tank has come loose or has a leak near the top. instead of fluid being pushed up the dip tube into the wand hose the air in the tank is just escaping. You will have to remove the wand hose and figure out where the leak is and fix the dip tube.
Nov 18, 2008 | H.D. Hudson 2g Yard N Garden Sprayer
Bissell 1698-1
the heater is blocked wih lime scale
Aug 25, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Dewalt 3700 Pressure Washer  Logo
407 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
