Question about Kenmore 75085 Air Conditioner
12,000 BTU Kenmore, almost new not cooling after non use
Unused for a year and when turned on, no cooling. Compressor not working?
    Novelist:
  • 145 Answers
Tray opening the a/c unit and see it there is a loose cable specially the real thin ones going to the control board i seen this problem before.
Posted on Jul 04, 2009
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
Compressor not running.
Haier Air Conditioner Compressor
modernemporium.urizyme.tk/512124/haier-air-conditioner-compressor
Using a ohm meter, and the compressor is cool to the touch, and the ac is unplugged, Disconnect the wiring to the ... Failure rate on compressors so far not including. ...Haier 12,000-BTU Energy Star Window Air Conditioner with Remote ESA412K-L. Consumer complaints and reviews about Haier Air Conditioner. Since air .
Jul 21, 2015 | Haier ESA412K Window Air Conditioner -...
Turned to the air cool setting for the season. worked at first then got intermittent flashing '61' and 'CH'. unit will not respond by remote or on the case
Condenser coil over 65°C. Check coil and filters are clean and free from debris, and airflow is OK. Check system pressures for non-condensables
Jun 06, 2015 | LG LMN126HVT LMN125HVT Ductless Air...
My sharp comfort touch air conditioning 12,000 BTU FS-S125FX-A does not cool any more. It's running but at room temp.
Can work the external drive and you see that turns the fan but look at the compressor he works; logically not working if the fan brings the temperature domatiou.antikatestise external capacitor again if the air conditioner does not work then the compressor is stuck.
Aug 07, 2011 | Sharp Comfort Touch AF-R120EX Air...
I have a Emerson Quiet Kool Model # 12JW42K that is 13 years old. It doesn't seem to cool the apt. anymore. I assume that it would be smarter to get a new "energy saving" unit than invest in...
I know that a Island Air units come in all shapes and sizes and they make a ton of different units. They are made in new york thats who I would use. I would definitly go with the 12,000 btu unit 500 square feet needs 12,000 btus 10,000 is under sized. 500 square feet divided by 500 = 1 ton of cooling. let me know if I can further assist.
http://www.islandaire.com/
Jul 23, 2011 | Heating & Cooling
I bought an amcor 12,000 BTU portable AC two years ago. I used it for a month, never used it last year, and then tried to use it yesterday and it is dead. As in, there's no response when I push any...
When a sett is kep unused for sometime the possibility of faults can vary as when it is in regular use.The best way for a first hand info is to trace the line of power fromthe controller unit to the compressor.Check the line to the compressor, if the control panel is faulty, check compressor relay, check capacitor.
Since it is failure of power, it can also be a wire break.
Sep 01, 2010 | Amcor ALTL-12000E Portable Air Conditioner
Frigidaire fac127p1a 12000 btu compressor
The compressor is probably going out on either a pressure related or heat related overload. Both are a result of low refrigerant. There may be a low pressure safety swich that protects the compressor. Otherwise it may be an internal thermal overload that is tripping. It resets itself and comes back on. The thermal overload heats up and shuts off the compressor to protect it from too much heat which is gernerated by not enough refrigerant in the system to keep the compressor cool. It may be cheaper to replace the unit than have someone try and fix it. It is pretty time consuming and you cannot try it yourself unless you have an EPA Certificate to buy the refrigerant. Check with your local appliance repair man to see if he will tackle it.
Jun 04, 2010 | Frigidaire 12,000 BTU Compact II Room Air...
Kenmore 12,000 BTU Room Air Conditioner ENERGY STAR
How many Square Feet is the ac rated for?How large of room are you trying to cool??
May 27, 2010 | Heating & Cooling
The unit is a 12000 BTU energy efficient model purchased from Lowes 3 years ago. It is not cooling. The fan runs fine but it just isn't cooling. The filter doesn't need cleaning. What could it be?...
The compressor is probably not running.
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Jul 30, 2009 | Frigidaire 12,000 BTU Compact II Room Air...
Kenmore 12,000 BTU unit 60days old compressor dead
  1. Sears or any firm that sells a Unit has to have a chance to look at the problem and repiar it, if you installed it WRONG that is Bad ! Sears will not be responsible for damge to the Unit, bring it to them, you might have to leave it for days - better to have a serviceman come to the home - Units are covered for 90 days all but Electrical ( ???) You better have the bill of sale ( date purchased ( not installed !! )
Jul 17, 2009 | Kenmore Heating & Cooling
Kenmore 75085 Air Conditioner Logo
118 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
