I have two red lines going from top to bottom. One line went away for a while but is back
  • 668 Answers
Chances are it is the Display Panel.
Posted on Jul 04, 2009
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
Hi, I have an Insignia 50 in plasma television that all of a sudden went to nothing but vertical lines, then popped a cuople of times and went black. Sound is still ok.Enybody have an answer for me as to...
this is a buffer issue.
do the line go through the menu if you display the menu when the lines are visible?
do the lines go from the top to the bottom of the screen or stop halfway there?
do the lines change colors?
if the lines go over the menu and all the way down to the bottom of the screen, then its a buffer issue, top and bottom buffer.
hopefully it's just halfway then you only have to replace the top buffer, less money to spend.
Nov 24, 2013 | Insignia Televison & Video
My samsung la40a650a1fxxy is ghosting and has horizontal lines
prob a loose wire from the inventer board to the backlight,need to open andsee.should be easy fix
Mar 19, 2013 | Televison & Video
Vertical red line through screen
This is a problem within the screen, probably the connection from the internal ribbon connector to the display. Unfortunatly the only way to repair this is to have the screen replaced.
Dec 26, 2009 | LG 42LC2D 42 in. LCD HDTV
Vertical white line goning from top and bottom. Help
The screen will probably have to be replaced. Try gently squeezing around the edge of the lcd where the line is present. Sometimes this will get it going temporarily. I have even used close pins before to keep pressure on it to keep it on. A new screen can be ordered on ebay for around $100 and are fairly easy to replace. I recommend getting the exact part number on the back of the LCD before ordering.
Dec 12, 2009 | Acer Aspire 5610-4648 Notebook
Color ink on transfer belt
I posted the problem on 4/6/09 about my HP Laserjet 2600n with the black line from top to bottom on all pages. The issues ended up being with one of the toner cartridges. I replaced them all - and the line went away! I will need to go back now and find out which one it was, and then I'll toss that one, and I will keep / reuse the others.
Apr 01, 2009 | HP Color LaserJet 2600n Printer
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Red line in top corner of screen
Sounds like an IC on the LCD panel went out of TV. Only thing to do is replace panel (it won't go away only get worse) It will probable be cheaper to just get another tv.
Apr 21, 2008 | Philips 42HF7444T 42 in. Plasma TV
Thin bright red vertical line from top to bottom of screen
that is the screen burned out. if still have a warranty return to company and get a return/exchange.
Oct 26, 2017 | Sceptre X7G-Naga 17" LCD Monitor
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
