When I pull the cleaning disc away from the corner it goes back there quickly and stays there.
Since this cleaner works on the principal that if run long enough it will clean the entire pool area, there is no real way to control its movements. try removing one length of the hose. this will change the pattern of the cleaner. you can also change the flow rate of the water and if you are using a weight, change its position. try only one fix at a time so you know which is working
SOURCE: baracuda G4 won't clean whole pool. goes to a corner and stays
Maybe your hose needs to be reprogrammed by unhooking and lying it in the sun for several hours.
SOURCE: I have had my Barracuda
Yes, it is possible. If that is the case, you will have to have it services by a Zodiac licensed repair person. There are a few things that you can try first, though. You might need to install a ladder guard. This is a common addition to these pool cleaners. If could also be an issue with your hose weights not being spaced correctly or your water pressure not being strong enough (use Star Control to check). If you can't fix it with one of these solutions, contact the technical service line at 1-888-786-7797.
Dismantling Altec Lansing VS 2221 speakers to clean the switch/volume control
Tools: a medium Phillips screwdriver, a craft knife & a can of CO contact cleaner & extension.
1. Remove switch/volume control knob by pulling it off
2. Pull out the base for the stand if attached
3. Unscrew the 2 screws beside the wires
4. Remove the front gauze by prising it out from one of the bottom corners. Keep the gauze straight as it will need to be put back from the bottom to the top.
5. Remove the 2 screws at the top and the 4 long screws holding the speaker. The back will come apart from the front and sides. If it has been glued then use the craft knife to carefully cut the back away from the sides and/or prise it away with a little pressure on the sides.
6. Attach the extension to the can of contact cleaner.
7. Lift the circuit board out and squirt only the switch/volume control. Ensure you squirt the shaft and the internal parts of the switch/volume control. Turn the shaft a few times.
8. Allow the contact cleaner at least 1 hour to dry.
9. Test the speakers. If the noise is still there then repeat steps 6-9.
10. To assemble the speaker do the steps 1-5 in the opposite order.
I hope this is helpful
