Question about Sony VAIO VGC-LT32E 22? All in One Desktop PC
Fan is loud
One of the 3 fans in my computer is really loud.I'm thinking of replacing them but i need to isolate the fan that is loud and also i don't know what specifications i need to meet for it to work could someone help?
  • Sony Master
  • 2,404 Answers
What needs to happen is you need to take all of the screws off of the back. Then there should be 4 screws on the bottom of the base but you need to take off the covers to them first before you can remove the screws.
Once all of these screws are taken out, you'll need to sepearate the back cover from the front, there will be latches that you need to move with a flathead screwdriver and you'll need to do this a few at a time so you can start removing the back cover easier.
You'll eventually remove the back cover to expose the insides of the computer. Now go ahead and plug in the Sony AC Adapter and turn on the computer and from that point once the fan gets loud you'll know which one you'll have to replace.
Posted on Jul 04, 2009
Fan running continuously
the fan in your computer is constantly running to cool down the cpu and it is normal for it to increase it's speed, your fan should run quietly even it increases the rpm. But if you hear a loud noise in the fan, i think there's something wrong with it. I suggest for you to check the fan if it's coming in contact with anything. If the fan is visible while your laptop is operating, you can observe it to know what is really happening. I don't know what type of fan hp uses on their laptops, maybe something is loose already on the fan so better check it or bring it to a service center.
Aug 06, 2012 | Computers & Internet
I have a Dell Inspiron 1521. 6 months ago the fan makes a really loud noise when the laptop has been running for a while. It went in June to be looked at because my computer messed up and they had to redo...
Yes, the fan can be definitely be replaced. You can actually get a replacement fan for your computer at The Laptop Fan Shop online for about $22. The process of changing a fan is quite simple, so you should be able to do it yourself to save on labor. Although, if your computer is still under warranty you should contact dell directly at 1-877-694-3591 to see if they can replace it for you for free.
Sep 16, 2011 | Dell Inspiron 1521 Notebook
My fridge is making a very loud noise coming from the rear and bottom of box.we have already shut it off for four hours it stopped making noise for a couple of weeks,but now started again,we shut it down...
THERE IS A FAN IN THE BACK OF THE FRIDGE , INSULATION GETS LOSE AND HITS THE FAN. REMOVE THE LOSE ISOLATION OR WHATEVER IS HITTING THE FAN.. I THINK THIS IS THE PROBLEM..JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 27, 2011 | LG Refrigerators
A friends computers fan is making alot of noise, sounds like the fan is going and making alot of noise, if you run 2 things at the same time it really gets loud. Is there an easy fix for this or is the...
hi
fan noise means one think, DUST !
or if its past its life cysle (ie: 3-5 years), its time to replace the fan.
you can remove the dust from the fan. If that noise persists, yopu must replace the fan , otherwise your friend will eventually dmage the CPU or mainboard or both.
hope this serves you well
Nov 04, 2010 | Computers & Internet
Fan is loud
well if its not attached to the motherboard in any place, for example the heat sync, or the cpu, then you can remove the fan, any other place, you shouldnt replace it because the mother board sets the fan at a certain rpm, and which would sound loud with any fan. I know this because i replaced the fan on my sony computer, and on a generic motherboard, and it was quiet, but when i put it on my sony computer, it was loud, so if you want to replace your fan, i suggest liquid cooling, it is completely quiet, and keeps your cpu much cooler than a fan. Best of luck.
Jul 04, 2009 | Computers & Internet
HP Dv8233cl fan grinding
You only need to replace the fan, not the heatsink assembly.
Your computer repairer can do it or you can do it yourself once you identify the size of the fan and buy a matching one. You may have to solder a new connector on the lead.
Apr 15, 2009 | HP Pavilion DV8233CL PC Notebook
Noisy fan
Clean the computer from dust, use canned air to blow the dust out, as the airflow increases the fan wont have to run so loud.
if the fan is really loud, it needs to be replaced.
Aug 11, 2008 | Computers & Internet
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
Sony VAIO VGC-LT32E 22? All in One Desktop PC Logo
240 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
