Question about Viking VGSC306-4B Gas Kitchen Range
Viking gas burners are too hot
Can I lower the heat setting on my Viking gas range? My low is too hot.
    Problem Solver:
  • 4 Answers
Yes you can but Im not qualified to tell you properly. Our gas guy came over with a long bladed slot screwdriver and lowered ours. IT CAN BE DONE!
Posted on Sep 06, 2009
Viking VGIC oven burners ignite but cycle off repeatedly temperature rarely gets to 300 after 30 minutes. If igniters ignite is problem elsewhere - like bad bi-metal valve? Range and broiler work OK,
There is a sensor that detects the oven temperature, it must be defective and sending a signal that oven is at set temperature and this shuts off the gas valve.
Nov 02, 2016 | Viking Kitchen Ranges
Basically my gas oven is not heating up properly, the temperature is not hot at all, and food is not getting cooked properly
this is a milti burner unit / and sounds like the ignitors or weak / look below the oven door edge for a glow if orange there bad they need to be white hot .. burners may come on but not all the time .. ****
Dec 05, 2009 | Viking 48" 6 Burner, Griddle Professional...
My Viking gas oven is slow to heat?
very likely the thermstat is defective, most likely the oven temperature proble
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
Need to know ohm reading
When room temp, you'll see about 80 ohms. As it heats the resistance goes up, and thus the amperage draw goes up, which is the critical component to release of gas and thus ignition. The ignitor needs to reach 3.2 to 3.6 amps before the gas safety valve will open and release the gas for ignition. Old ignitors get weak and even if they still glow they may not draw enough amperage to allow the oven to work. Also, low voltage will result in lower amperage draw and possible ignition problems.
Nov 28, 2008 | Viking VGSC306-4B Gas Kitchen Range
Gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Feb 05, 2008 | Kitchen Ranges
Electric Cooktop Heating Elements Get Hot, Turn Off, Get Hot, Turn Off
no they are made to cycle that way they are halagen and cycle with a sensor dont work like the old coil ones do enegey efficent and hotter than old coils dont use them without a pan on them to reflect heat back to the sensor to prolong their life
Dec 29, 2007 | Viking 31 in. VGSU101 Gas Cooktop
Viking VGSC306-4B Gas Kitchen Range Logo
181 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
