SOURCE: hOW TO ADJUST A MODEL 34122 gROHE VALVE
there should be a flat head screw on the mixing valve turn the water on and turn it to the desired temp,, it is letting to much cold water in , if this does not work replace the mising valve
SOURCE: Grohe Thermostatic Valve
the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
SOURCE: grohe shower
if you pull the handle off all the way back to the valve body there is a little black stopper around the cartridge body that you can adjust by pulling it out and sliding around the cartridge body this enables people to just turn the handle to one setting and jumpping in to their favorite temperature. in your case it doesn't allow you to have any cold water. so turn it one way see if you get what you want or try the other or some of them you can even just take the darn thing out and not even have to worry about it
SOURCE: We have a Grohmix shower valve and we are unable
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
SOURCE: Install trim and adjust the thermostat on a Grohe shower faucet
