Question about Carrier 36KCARMS Air Conditioner
Compressor fan moter not working - Carrier 36KCARMS Air Conditioner
  • 30 Answers
It is likely the capacitor for the fan motor. Unless you are comfortable working with 240v this is an issue for a qualified service tech. If you are comfortable with it, replacing the capacitor is fairly simple, you can probably obtain one from most electrical supply houses. It would be the smaller of the two capacitors contained within the exterior unit, the larger one is for the compressor motor.
Posted on Jul 04, 2009
We have an Emerson IM90 portable ice maker which has worked fine for months. Now it is only making 5 ice cubes per baych. Any ideas?
when mine did that i got out the air compressor and blew all of the dirty and stuff off of the moter and low and behold it worked great but be carefully I tore a blade off the fan and now it runs alittle noisey. still makes great ice now I gonna find another fan blades. you need to unscrew the back to do this.
Aug 29, 2012 | Emerson Im90 Portable Ice Maker
My electrolux ERN2820 is not working the light is on the moter is running but the freezer is defrosting and the fridge has lost it temp
Have you cleaned out the coils lately? Sometimes they become full with dust and will not cool properly. If the coils are clean, check that the fan is running. If the fan is running, maybe the compressor isn't. If the compressor is running and all else looks good it is probably low on freon.
Feb 03, 2012 | Electrolux ERN2820 Bottom Freezer...
The refrigerator is not cold.
compressor not work check power and relay. evap fan and condensr fan not work? check power ,if power ok . replacement moter .condensor dirty? cleaning up
Jan 11, 2011 | Jenn-Air Refrigerators
Air condition fan not working and inside the vent is not cooling
fan moter may be bad if it will not run it will cause the compressor to overheat and it will not cool also check the capasitor
Aug 12, 2010 | Goodman CKL42AR42 Air Conditioner
My side by side fridge has stopped chilling down, the power is Ok, and moter seems to be working, but no cold inside. A few months ago the freezer side stopped, but as i did not use it , i just left well...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Whats the bottom moter with fan for
Refrigerators have a condensor fan so it can cool the compressor otherwise the compressor overheats and turns off.
May 11, 2009 | Refrigerators
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Hi...need help...subzero 550
Make sure the condensor is clean, blow some Air though the Condensor to make sure good Air flow towards Compressors. also, you might have a bad defrost timer or Freezer Control... worst case you might have a bad Compressor... hope I can help....
Jan 16, 2008 | Sub-Zero Bottom Freezer Refrigerator
Warm fridge and freezer...
first make sure the condennser fan moter is working located beside compresser.
Dec 14, 2007 | Jenn-Air JFC2087HRP Side by Side...
Carrier 36KCARMS Air Conditioner Logo
180 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
