Question about Westinghouse SK-32H540S 32 in. LCD TV
Tv wont turn back on
Okay i posted in wrong location lol. But anyway The Cord has power to it from the outlet but none to the TV wont turn on so do you think it could be the Ac Supply? or a Fuse?
  • 43 Answers
Power Supply could be bad. If TV doe not power on at all then this would be the culprit. But is TV powers on with sound but no picture then I would suspect the inverter board which is a common item to fail in westinghouse flat panel tvs. You can usually order this board seperately. Good Luck
Posted on Jul 04, 2009
  • 221 Answers
Either of those, so check both.
Sony Bravia built in DVD player wont accept the discs - why is this?
Performing a power reset
1. Turn off the television.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
How to establish an HDMI connection between a TV and other device.
Follow the steps below if the HDMI® connection between your TV and other device is not working:
1. Make sure both the TV and other device are turned on.
2. While turned on, unplug the power cords for the TV and device from the electrical outlet.
3. Disconnect the HDMI cables from the TV and other product.
4. Wait 60 seconds.
5. While the HDMI cables are disconnected, plug the power cords back into the electrical outlet.
6. Turn on the TV.
7. Re-connect the HDMI cables.
8. Turn on the HDMI-connected product.
The TV should now detect the HDMI signal from the connected device and operate normally. If there is still a problem, disconnect the HDMI cable from both products and then reconnect it in the opposite direction. In some situations this has been reported to resolve connection issues.
How to reset a TV to factory settings: https://us.en.kb.sony.com/app/answers/detail/a_id/61396
Hopefully this post helps you! If does, please mark it "accept as solution"
Aug 20, 2017 | Sony Televison & Video
HI NEED HELP? TV WONT TURN ON?
Unplug the power cord from your TV. Wait 30 seconds, then plug it back in. Plug the power cord into a different power outlet or power strip. If possible, try a different TV power cord.
Apr 13, 2017 | Televison & Video
How can I find if cord is essential for operating TV. ModelKDL40EX, Serial.1733885 Feb/2010.
of course it needs the power cord . none are total battery operated .
Oct 08, 2016 | Televison & Video
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
Tv come with no sound or pict.
Check whether the product is turned on.
Try another channel. The problem may be with the broadcast.
Is the power cord inserted into wall power outlet?
Check your antenna direction and/or location.
Test the wall power outlet, plug another product's power cord into the outlet where the product's power cord was plugged in.
If these tips don't work, you can also try to power cycle the TV. Turn the TV off and unplug it for about a minute. Plug it back in and power it back on to reset the settings back to factory default.
Oct 18, 2013 | LG 32LG30 32 in. LCD HDTV
SAMSUNG LN52B610 TV TURNED OFF BY ITSELF. CANT TURN TV ON. NO RED LIGHT ON TV FOR POWER. OUTLET WAS CHECKED AND HAS POWER. CORD IS IN GOOD CONDITION. PLUGS FIR SNUG IN...
Hello.
If you have multimeter available you can actually check if voltage present at the end of your power cord first.
If it's OK than you have to remove back cover from your TV and locate power supply board. It's very easy - it should be next to the power cord receptacle. First look for capacitors that have bulged tops instead of flat ones. If you locate any - replace them and check if it's going to take care of problem.
Right next to receptacle connection is fuse located and you have to check if it's open. Replace it if needed. If new fuse got blown right away - you have short in power supply board. If fuse is OK - connect power cord and using multimeter try to figure out if 5V is supplied from Power supply board to the main board (the one that have all inputs attached to it). If 5V is present but power LED in front of the TV is still dead - you could have problem with main board.
Best regards.
Russ.
Aug 17, 2010 | Samsung LN52B610 52 in LCD TV
I have DMTECH TV/DVD LT20X-1U23DMI .... LT1AHA02042 manufactured in October 2007. The TV doesn't turn on/doesn't have power. The outlet is fine. I've tried another working outlet without success. How do I...
Assuming that by "working outlet" you mean something else like a lamp will work, then, the first thing is to make sure its the TV and not the remote control. If the power switch on the TV will power the unit, the the remote probably has dead batteries.
Assuming it wont respond to either the power swtich on the TV, or the remote, then look on the back of the set for a reset button and push it. Some units have a sort of circut breaker. It may be best to do this with the unit unplugged.
If none of this works, then try moving the cord around. If the TV will power up depending on the cord position, then you have a bad power cord, which is a pretty easy repair.
If none of this works, then the chances are that you don't have a Do it yourself kind of problem
Jul 03, 2009 | Televison & Video
None working Polariod FLM 2601.
Hmm,
Might be a bad connection inside set, but might want to get the obvious stuff out of the way first.
1. Verify outlet is working by plugging something else into it.
2. Make sure the ac cord is pushed in all the way into tv. Might not be making good contact.
3. Double check to make sure tv doesn't have a power on/off switch. Some TVs have a power button and also a power switch somewhere on the bottom or back of set that might've been flipped off if there is one.
Apr 26, 2009 | Polaroid FLM-2601 Television
Emerson LCD 32" TV....Model # LC320EM82....Power problem, powers up and powers right back off almost instantly....i have tried to google a solution and so many people are having the same solution but...
Okay!First i need to isolate your electrical outlet is working. Use another Video/Audio component(ex. dvd player) and plug the power cord into the TV outlet,be sure it has nothing to do with the outlet.
If the outlet is working properly,Unplug the TV power cord and wait for 1 minute before you plug it back in the outlet.Turn on the TV MANUALLY without the remote control and see if the power stays on,if not,sorry,you need it to be repair.Don't waste more time on it. If you only purchase it for few months with a reputation retailer,there is no reason NOT to call them up,cause it should be still under warranty?
solutiondoct
Nov 10, 2008 | Televison & Video
Westinghouse SK-32H540S 32 in. LCD TV Logo
275 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
