Question about Alpine Car Audio & Video
Amp keeps cutting off
The amp will turn on until the beat drops, then the amp will go into protection mode and cut off. This whole cycle goes on about every 8 seconds. Im not too sure what the problem could be. Ive checked the speaker wires, rca cables, and the fuses on the power wire and the amp. It could possibly be the ground wire, but my connection has been pretty good since I first put the ground wire in a while ago. I just dont want it to be the amp. I greatly appreciate it.
P.S. All of this started when the amp cut off one day as I was making a pretty sharp turn.
KaeZoo
  • 156 Answers
SOURCE: Protection light and nothing. ??
How about the speaker itself? This problem can be caused by a blown or defective speaker. If you disconnect the speaker wires from the amp, do you still get the protect light?
Posted on Mar 15, 2007
SOURCE: Amp goes into protection
First change the wire,and disconnect the subwoofers to check if the amplifier turn on without going in to protection mode,if the amplifier go to protection mode you gotta change the Audio amplifiers IC's because they are in short circuit.And if don't go in to protection put one speaker at a time to check if one of them are damaged.Good luck.
Posted on Jun 02, 2008
bigTROY502
  • 129 Answers
SOURCE: Amp in power protect
A blown speaker will trigger the protect mode, sotry to power upthe amp with the speakers disconected, If you are still in protect, then the amp is bad.
Posted on Aug 08, 2009
  • 113 Answers
SOURCE: amp overload protection mode
it sounds like the ground is bad to begin with and check the positve cable for oxidisation on the battery terminal and at all other places that the power wire is connected to
Posted on Aug 09, 2009
  • 150 Answers
SOURCE: JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Posted on Jan 16, 2010
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
What cause my 15 speaker go off when the beat kick in but the amp still on n make noise out da speaker
Sounds like it's overloading you may have a sub to small for your amp cut all the settings on your amp back to minimum wind them up until sub cuts out then drop them back a bit .
Aug 01, 2014 | Car Audio & Video
I have a power acoustik ibm12000d amp had it installed to weeks ago wired at one ohm to a 15inch acoustik p3 sub worked good for to weeks hit good and everything but now its cutting off when turned up I...
Sounds like an over current condition. Your sub may be the problem. Does it go into protect mode when it cuts out? remove the sub and turn up the volume and see if it cuts out when you keep increasing the volume. If not, then it may be that the sub shorts out when turned up too much, kicking the amp into protect mode. If it still cuts out, then it may be the amp. Try another sub if you have one or borrow one from a friend.
Aug 06, 2011 | Power Acoustik OVN1-2000D 1-Channel Car...
Amp overload protection mode
Aug 09, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Do you have heavy enough gauge wire supplying B+ to amp.Big amps draw a lot of current and require very heavy gauge wire. The longer the run the heavier the gauge needed.
Apr 20, 2009 | AudioBahn A8000T Car Audio Amplifier
MY AMP GOES ON PROTECT MODE WHEN I TURN IT ON
Very likely to be a bad earth.
Check the earth connection to the chassis of the vehicle. Remove the screw/bolt and clean around it with a wire brush or wire wool.
May also be a good idea to check for continuity using a multimeter.
Remember to try to have the earth connection as close to the amp as possible, as this will cut down on the risk of a bad earth and will minimise interferance.
Apr 13, 2009 | Car Audio & Video
Sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
My Boss Amp keeps cuts off when I play the music from my stereo
check your ground wire and your remote wire, Wiggle them separately both at the amp and at the ground point. See if it cuts out then, and you;ll know which one. Also, does it have a light on it when it cuts out? if so, it could be going into protect mode, which wont allow it to turn on for a period of tine. Make sure the amp is not too small for the speakers you are pushing.
NGK
Sep 03, 2008 | Boss Car Audio & Video
Sonamp 260 cuts out
Normally this denotes a protect condition. Remove the speaker wires from the back of the amp and see if the green light stays on. If this fixes the problem, then there is a short circuit in your wires, speaker level volume control or speakers. The amp sees the short and goes into protect. After a couple seconds it closes the connection again and if the short is still present it goes back into protect.
Aug 03, 2008 | Sonance Sonamp 260 MKII 2-Channel...
Cutting out intermittent problem
If the voltage is dropping to 8v, it sounds like there is a problem with either the B+ line or the ground connection. You should also check the voltage across the battery terminals to see if the voltage is dropping at the source.
The amp may be going into protect mode. Disconnect all speaker wires from the amplifier's terminals. Also disconnect the RCA cables from the amp. Does it still go into protect?
Insert a 20 amp fuse in the B+ line and try to power it up. If the fuse blows with no speakers connected to it, the amp probably has a blown channel.
Dec 05, 2007 | JBL GTO75.4 Car Audio Amplifier
Car Audio & Video Logo
101 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
