Question about Compaq Presario X1000 Notebook
Compaq Presario 1000x charges when off, but not when on
I plug the laptop in while it is off and the charging light comes on. When the computer is turned on, it stops charging and no amount of wiggling will get it to charge.
As soon as the computer shuts down, the charge light goes on and it charges again.
Any idea how to fix this?
  • 2,404 Answers
Try a different battery cause your existing one may have bad cells and could be messing with things. Try one that you know that works. If that fails, try another AC Adapter and see if that changes things.
If neither one fixes the problem. It could be a problem at that point with the dc jack. The solder points probably need to be resoldered cause the connection isn't good.
Could also be a problem with the motherboard with the voltage regulator but try my other suggestions first to rule things out.
Posted on Jul 04, 2009
Battery problem with HP Compaq Presario V2000 laptop
When batteries fail, they usually lose the cells inside them, which means that the cell is no longer able to function as a holding cell for power and therefore cannot do its job anymore, when a battery fails to hold and refuses charging it is bad and needs to be recycled. The flashing is telling you to purchase a new battery. The larger the number of cells in the battery, the longer and better it will perfrom,,RE: 6 cell, 9 cell, 12 cell.
Jan 13, 2010 | HP Compaq Presario V2000 Notebook
Just purchased a compaq presario secondhand--is the battery supposed to charge automatically when you plug the computer in? Mine is not. Works perfectly with the power cord though.
All the laptops I have seen since the 1980's charge the battery, if it is installed, while the laptop is running. They charge at a slower rate if you are using the computer, and faster if you just plug it in and leave the computer powered off.
Most have a 'charging' led [green or amber] indicating that the battery is being charged when you plug the laptop in and leave it turned off. If you don't see any indication, check that the battery is connected firmly and that the connectors are not damaged. If possible, try the battery in another machine or a different battery in your machine.
tom
Dec 21, 2009 | HP Compaq Presario V6000T Notebook
Laptop comes on and then goes off. do not know if it is the adapter or the laptop, it is the compaq presario CQ50
plug in adaptor if charge light does not come on its adaptor if it does you have a hardware problem
Nov 03, 2009 | HP Compaq Presario CQ50-210US Notebook
Blinking power and charge lights
The power plug on the laptop seems to malfunction. Or the Jack is loose.
Oct 12, 2009 | Compaq Presario Notebook
Charging, but no power compaq precario
Hello, Did you twist any of the wires/cable on your charger? Can be a problem on the plug, try, very gently, to turn it, if round that is, and see if theres is a contact in between. Regards.
Jun 11, 2009 | Compaq Presario Notebook
Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
May 23, 2009 | Compaq Presario 700 470024-192 Notebook
Laptop won't turn on, battery won't charge
I had a similar issue with the Armada M700 from Compaq. Never did figure it out exactly. But I do know this. When you unplug the power chord and take out the battery and plug the power chord back in while the battery is out usually for some reason it turned on allowing me to replace the battery which would then begin charging. Your problem interests me because I can really relate!
Jan 14, 2009 | Compaq Presario 1200 Notebook
Laptop Charging Help!!
you should get your laptop plug fixed for sure.
Patrick
Oct 18, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Compaq Presario X1000 Notebook Logo
77 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
