My air conditioning blows hot air only, nothing
My air conditioning blows hot air only, nothing electrical is wrong, what else could it be?
  • 116 Answers
Ok if unit is split system two piece check to see if out door unit is running fan and compressor the air coming out of the fan should be about 20 deg warmer than out door temp if not compressor not running check the capicitor to see if swelled up on top if so bad if unit has electric heat strip a heat relay may be stuck and you are running aug heat to check this pull disconect on out door unit and see if heat is out of vents if heat pump reversing valve may be bad hope this helps
Posted on Jul 04, 2009
Air condition
What's Wrong With My Car's Heater? - Popular Mechanics
www.popularmechanics.com/cars/.../whats-wrong-with-my-cars-heater-1...
... hot air you need. Here's what to do if your vehicle is struggling to turn up the heat.... In the recently chilly mornings I've noticed my heater isn't putting out hot air. ...Surely it's not saying it won't play the DVD because 1 doesn't match Free. And, yes, it.... The Nurburgring Nordschleife should need no introduction. Nearly 13 ...
How to Fix a Car with No Heat (Easy) - YouTube
? 10:56
https://www.youtube.com/watch?v=-XjXTVJhFLM
Nov 21, 2014 - Uploaded by ChrisFix
Car not blowing hot air? This video will show you how to fix yourcar's heater whether it is your heater ...
Car Heater Not Working - Troubleshooting Repair Tips ...
? 4:05
https://www.youtube.com/watch?v=aCkVjiPZA4o
Oct 1, 2013 - Uploaded by WiseAutoTools
When troubleshooting to try and repair the car heater, check the coolant ... If a cooling system is full and there's still no hot air coming from the vents, .... Hi I have 2001 ford expedition and theheater just blows out cold air and ...
Dec 29, 2015 | Cars & Trucks
When I press the button to change the speed of the fan it does nothing, and continues to blow at one speed and it is just about equivalent to the speed of the slow option...any ideas why? Also it will run...
Is it new? There may something wrong with the electronic circuit board not allowing other fan speeds. Try unplugging it for a while and try again. There is a temp sensing bulb somewhere on unit most likely on front where hot/warm air from space enters unit. Make sure you are not recycling cold conditioned air back onto sensing bulb.
Jul 20, 2013 | Heating & Cooling
Odyssey air conditioning
HVAC Vent Doors under the dash- need to be diagnosed
One is not operating- to switch the air flow
HVAC Vent Door Motor or Vacuum Motor
which ever type you have
Jul 18, 2013 | 2005 Honda Odyssey
Air conditioning blows cool then blows hot what could be wrong in my jeep grand cherokee larado 1995
Is the compressor working when the ac starts blowing hot ?
Is the radiator fan working ?
Aug 05, 2012 | 1995 Jeep Grand Cherokee
Fan works, fuse is good, compressor does not click
Could be low on freon, a faulty pressure switch, relay, or fuse.
Jul 08, 2012 | Chevrolet Cars & Trucks
Air conditioning blows hot and cold air
You will need to know if the compressor is working when it blows hot air to proceed. It could be an electrical problem, a blend door problem, or the a/c clutch on the compressor.
Jul 02, 2012 | 1999 Honda Civic
I have a merc e240 2000 model and has some problem in air condition it blows cold air from one side and hot air from other side
I may be wrong, There is hose that is off its place in the hot side, or the flap that closes the hot channel is not working.
Jun 24, 2011 | 2000 Mercedes-Benz E-Class
My 2002 Hyundai air conditioner blows HOT air..any solutions??
Well there are a number of things that can be wrong here. You may have a coolant leak, You may have electrical problems or a bad compressor. There is no easy way to figure this one out. I suggest you bring it in to the shop and have it tested. Most places will charge about $40 to $50 for a check-up of you Air Conditioning systems.
Jun 12, 2011 | 2002 Hyundai Santa Fe
Air conditioning is working but it only blow hot
several things could be wrong such as low freon or a bad vacuum line or switch controlling the door to open for a/c
Aug 02, 2009 | 1991 Lincoln Town Car
Heating & Cooling Logo
415 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
