Question about SanDisk Sansa e250 MP3 Player
Built-in memory my problem start with the refresh data base (connecting to a computer) then i reformat it unfortunately when i'm synchronizing the songs that i want, the memory says zero memory, but it should be 6 gb since it is empty. Thanks for anyone who can help
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
"When I try to sinc my blackberrycurve to my
Try these simple steps: 1) Disconnect your Blackberry from your computer 2) Start DM (Desktop manager) and on the upper right hand corner select Options 3) Select "Data Folder Options" 4) Choose "Use this specified folder" 5) Right click the data path and hit "select all" and copy 6) Hit Start and select Run 7) Paste data path into run and hit ok 8) Blackberry folder should open up 9) Find the "Intellisync" folder - select it and delete it 10) Connect your Blackberry 11) Go to your DM's main menu - select "Synchronize" 12) On the left hand side - select Configure Synchronization 13) Press "Synchronization" button 14) When done - select Synchronize (Upper left corner) 15) On the synchronize screen - select only "Synchronize Organizer data" and "Update device date and time" 16) Select "Synchronize"
Jan 06, 2011 | RIM BlackBerry Curve 8310 Smartphone
How unlock my memory card password
unfortunately no way to read your card password but there is way to reformat it but all your data will be deleted...using password remover gadget ,your memory card will be corrupted then afterwards its ready to reformat..insert in your phone ,selecct extra ,then tools,memory card and there is an option to reformat then select it..thanks
Jun 11, 2010 | Nokia 6600
No music adds
To reformat the NWZ-S545 Walkman follow these steps found on page 92 of the operation guide:
Formatting memory [Format]
You can format the built-in flash memory of the player.
Note:
  • If the memory is formatted, all data (songs, videos, photos, etc., including sample data installed at the factory) will be erased. Be sure to verify the data stored in memory prior to formatting, and export any important data to the hard disk of your computer.
  • Be sure not to initialize (format) the built-in flash memory of the player using Windows Explorer. If you have formatted with Windows Explorer, format again using the player.
  • This function is only available in the pause mode.
  1. From the [Home] menu, select [Settings] / [Common Settings] / [Format]. [All data including songs will be deleted. Proceed?] appears.
  2. Select [Yes]. [All data will be deleted. Proceed?] appears. To cancel the operation, select [No].
  3. Select [Yes]. When initialization finishes, [Memory formatted.] appears. To cancel the operation, select [No].
Mar 26, 2010 | Sony Network Walkman NWZ-S545 Digital...
How do you remove corrupt data from a memory card. As the normal delete fails to remove the block. Thanks John
Stick it in a pc and reformat it.
Once in, go to my computer to see it, then right click and choose reformat.
Mar 04, 2009 | Sony PlayStation 2 Slimline Console
After reformatting my fujitsu lifebook n5010 it doesnt read it.
Is the card reader built into the computer?
I know there are a few card readers out there having trouble reading 2 gig memory cards if the computer or card reader was built over 5 years ago.
If you have a data cable for your phone and software for the phone, your computer should be able to read it that way.
Nov 12, 2008 | PNY 2GB microSD Memory Card
Quin_168@yahoo.com
for this you would need a few things handy before you start off. first move all your data like pictures and songs from the phone memory to the memory card. now you would need to have nokia pc suite installed on your pc and you would need a data cable compatible with your phone. keep your phone in general profile and make sure the battery is full. connect the phone to the computer. the computer would recognise and install the usb drivers for the phone. now open nokia pc suite and configure the phone. next click on backup phone data on the nokia pc suite main screen. now it would backup all your data from the phone like contacts, sms, settings etc onto your computer. next click on software update. the suite would search for the software (note: you need to be connected to the internet) and would turn up with the software for your phone. now the installation would proceed. once it is done, again click on backup and restore the data from pc to phone. the reformat is done!
Aug 19, 2008 | Nokia N70 Cellular Phone
RECOVER DELETED DIGITAL PHOTOS AFTER REFORMATTING
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this camera photo recovery software
http://www.asoftech.com/apr/
Install and open the photo recovery software, select the memory card, and click 'Start' button.
Mar 20, 2008 | Cameras
Clarification
well,
always assume that whenever you buy a usb interface card reader/writer... it always stores and copies data. you can either delete any data there and the latter. store it.
never the less, advise you to tell him/her that whenever card is corrupted, always look for a solution to reformat it. but reformat cannot do it... well, thats another problem. :)
Feb 02, 2008 | Nokia 3230
SanDisk Sansa e250 MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
