Question about Xerox Office Equipment & Supplies
Error code U6 I just purchased the copyer and when I was setting it up pluged it in turned it on and error code came up I looked in the user manual and discovered that I needed to turn it off for 5 min. and then turn it back on i did this and error code U6 came up again. can you help with having to call a service person.
  • 30 Answers
U6 is probably a cover is open or broken check all the covers and doors and make sure they are closed
Posted on Jul 07, 2009
Toshiba 207 -f14
Hold down the key's "0", "8" and start the copyer.
After that it will apper (AD) or (ADJ), tst "389" and press the start key.
Then turn off the copyer and turn it on again,that's it.
Jul 03, 2014 | Toshiba e-Studio 207 Copier
Minolta error disply on ( pc )
What code show in the display and what you do clearely describe
Aug 18, 2013 | Minolta Di152 Laser Printer
U6 Error code on dish drawer
It might be helpful if you provide the model number of your dishwasher. It is likely the dishwasher has been set at a water pressure setting different to your mains pressure. If you are in normal water pressure area the selection is HI otherwise LO. Depending on the model the setup information is different.
Jan 26, 2013 | Fisher and Paykel Dishwashers
We are having xerox 1038 model usa made . we are getting the error u6 when we switch on our machine . so plz suggest us the best possible way to fix up the problem ...`````
U6-1 The main PWB failed checking the ROM.
Shut down and restart the copier. If it appears again U6-1, replace the main PWB.
U6-2 The main PWB failed checking the RAM.
Shut down and restart the copier. If it appears again U6-2, replace the main PWB.
U6-3 and U6-4 The main PWB failed to check the battery MNV (U6-3). Or the main PWB does not properly initialize the NVM (U6-4).
Follow the procedure in the development of memory to initialize the NVM, code 20-96. Shut down and restart the copier.
Jul 20, 2011 | Office Equipment & Supplies
My Copyer Has an error (H4)When the Electicity Voltag was Down The machin was on. I thing this is Copyer Problem. Please Help me
Peform the following procedure to enter the simulation mode and canceling the code ;-
"#" key ? Interrupt key ?"C" key ? Interrupt key ? 14 ? Start key
Dec 24, 2010 | Sharp AR-5320 Black and White Copier
Error F14 in my Toshiba e-studio 166
how to reset error code f14 in the toshiba e-studio 160
May 12, 2010 | Toshiba e-STUDIO166 Printer
Mi copiadora sharp AR5125 tiene codigo U6
code Sub code U6 00 Content Desk communication trouble Detail Failed communication with desk Communication line test error occurs when power is turned on or after the exit of a simulation mode. Cause Improper connection or broken wire of connector or harness Desk control PWB defective Control PWB (PCU) defective Malfunction due to noise. Check and remedy Clear the trouble by turning the power supply On/Off. Check communication line connector and harness. U6 01 ~ 03 Content Desk 1, 2 and 3 CS lift-up trouble Detail Desk cassette lift-up trouble (1st - 3rd cassettes). Cause Defective sensor RADF control PWB defective Broken gear Lift-up motor defective Check and remedy Check lift-up sensor detection with SIM4-2
Nov 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
I Have Xerox 5821 Star Copier and it got U6 error. Help me out
U6 code means that you have a problem with the exposure lamp or exposure lamp circuit working properly.Hold down the 0(zero) key while turning the unit on and punch in the codes 20 start 3 this will enable you to clear the code unless you have a permanent problem where a part has to be replaced
Apr 21, 2009 | Xerox 5100 Copier
Phaser 7300 Error Code/Message
Seems to be something to do with the Ram.
More help HERE
Jun 01, 2008 | Xerox Phaser 7300DN Laser Printer
384 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
