Question about Ariston Technologies AWD121WH
Ariston margherita washer dryer awd12
You turn the washer on, on a program , light flashes as should, then click like should ,light stays on like should , then nothing no filling . have tryed to dry , nothing
please help could it be the electrics?
  • 1 more comment
  • crqdnb Nov 10, 2007
    recently acquired an Ariston Margherita 2000 but cannot get dryer to work. Any ideas?
  • Anonymous Jan 14, 2008
    i have same problem ariston are as useful as a chocolate tea pot but the so called bloke offering his opion as to how to fix it is nonsense, the machine is as good as dead. the reason its not filling, drying is because the program selector is not advancing round. the machine is not carrying out any tasks not filling not emptying not spinning .
  • Anonymous Mar 20, 2014
    when you start a cycle the red light keeps clicking ,I have cleaned filter and tipped washer on sides nothing in there I have tried new door switch ,no change , I have tried removing plug to reset no change
To dry you need to turn the program to the little 'star' sign after the program 8 and not before. You then need to select the time you want the dryer on for, if you don't select a time the dryer doesn't come on...........not filling is a problem, it may be ythe electrics or it may be that there is something wrong with the door -if the machine thinks trhe door isn't closed it won't fill up but this machine generally uses a small amount of water and wil not actually fill up as such anyway......hope that helps!
M
x
Posted on Nov 21, 2007
Hi, I had purchased second hand MARGHERITA 2000-AB63 Washine Machine. BUt i dont have manual to operate. Pls Help.
i have ariston marghrita 2000 AB 63 it does not clean cloths and does not dry cloths.whenever i takeout cloths they are so wet that water drops out of these cloths. pl tell me what shall be position of different buttons and knob when i wash wash cotton/tetron mix cloths
Oct 25, 2010 | Ariston Technologies Ariston AWD12 Front...
I CAN'T FIND THE FILTER IN THE ARISTON MARGHERITA 2000 AB43 IN ORDER TO CLEAN IT
The filter is usually in the top tray or bottom in the little square.
Hope I helped
Dr Reed
Apr 06, 2010 | Ariston Technologies Ariston AWD12 Front...
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Aristin Margherita 2000, motor is silent after I put the clothes
turn the wash temperature dial to zero,
if it starts to wash it could be a faulty thermostat,
if that wont wont work it could need new brushes in the motor
Mar 15, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Feb 13, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston margherita washing machine
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
Thanks & regards
ray salac
Aug 16, 2008 | Ariston Technologies Ariston AWD12 Front...
Hariston margarita a1324 advantage
hiya
dont remember giving assitance before but i'll try and help you if i can. when the machine starts to click around count how many times the doorlock/on off light flashes as this indicates a fault code. it will usually go something like, flash pause flash pause etc until it flashes quickly then it restarts the fault sequence.
if you could let me know how many times then i'll be able to diagnose the fault quicker.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 13, 2008 | Ariston Technologies Ariston AWD12 Front...
Ariston Technologies AWD121WH Logo
770 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
