Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
One drawer totally stuck
We just use the bottom drawer on our washer now because the controls on the top drawer are stuck in Rinse/Eco :(
Hopefully I can find how to change the control board on this site.
I have had this problem too. You need to make sure the top lip of the inside of the drawer is dry. I usually just take a paper towel and dry that area off and then it works.
Posted on Jul 21, 2009
Fisher and paykal DD. Top drawer stuck on Eco and fast wash. Buttons not responding to touch.
If this is part of warranty repair then the technician should be asked to come back and fix. Try to turn off mains power and then use a clean damp cloth and run on the program selection panel on top of drawer lid. But most likely some dirt on the underside of the panel. Need to take controller out and clean it.
Feb 28, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
WA37T26 rinse/spin cycle
if it is set on Eco it will do a lot of spray rinse cycles to save water.
Aug 15, 2017 | Fisher and Paykel WA37T26 Top Load...
What does the 'eco option' on the MW512NZ model actually mean?? Cheers
Eco is a water saver option, using less water on the rinse cycle. It saves 25% more water than the water saver option on the rinse cycle (if available, depending on model). Eco and water saver cannot be used with fabric softener. Eco and water saver are slower than the regular rinse cycle.
Smartdrive User Manual
Dec 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher and Paykel 2-drawer dishwasher. The top drawer is stuck in the rinse cycle and I cannot change it to another cycle. Please advise.
Assuming the controller of the top drawer is still ok, take a clean damp cloth and wipe the top panel where the program keys are located.
If nothing happens, you will have to check if the controller connector is not loose. Take the front cover off and check the controller connectors.
Please rate this solution to help fixya serve you better in future.
Sep 16, 2010 | Fisher and Paykel 23 in. DD603H SS...
Programming
Your dishwasher drawer appears to have got stuck in some sort of a diagnostic mode. The 3 lights are a code telling which diagnostic it is in.
I am assuming you have turned off and on at the mains power and it makes no difference.
I need to check a few things with you first, but I am assuming the controller is not looking good. The easiest way to confirm this is take the controller from the top one and try it below. But you need to feel comfortable doing it.
Let me know if you want to call a technician or do it yourself.
Jun 20, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Water leaking back into top drawer, resulting in error that prevents the cycle completeing
It is good that you identify the leak from the top drawer. Now it time to clean it. Pull out the tube. Near the bottom there is a squares tab on both sides. Press these tab so the tube could be pulled further out so you can lift the tube out of the rails. Push these rails in then you can lower the tube to the floor to dry out the wetness inside the housing. You can use the bottom drawer while deciding to fix the top drawer by yourself or call the F&P serviceman. If you decide to do your own then need to order the Lid seal with YOKE and a pair of actuators. THe original problem is the actuators,not holding down the lid seal so there was a leak. However, when it is bad it causes the lid tilted in one side then damages the seal from the lid. If you don't mind the time, when you replace the actuators keep original lid in until it leak the replace with a new lid. WHen change the new lid you have to change the YOKE since the replacement had a new design better than the original so they are different. Good Luck.
Dec 17, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washing machine will not spin or drain
look at my post "eco smart won't drain, smells hot". It could be something stuck in very lowest part fo drainage area. you have to remove the motor on bottom of washer to see into this area and remove blockage.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Broken washer
could be clogged drain. look at my issue "eco smart won't drain, smells hot" on how to remove motor from bottom of washer and check lower drainage area. bail water out first and be ready to catch water when you remove that motor unit.
May 14, 2008 | Fisher and Paykel IWL12 Top Load Washer
Bottom drawer stuck on 12 min cycle(rinse only)
Turn power OFF at main power point, then
Turn power ON.
Check that the "ECO" button is no glowing.
Good Luck!
Feb 13, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
233 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
