Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
How do I operate the self cleaning function on my Kitchen Aid Superba double oven circa 2007? It has an electronic touch panel.
Do not know if the above "Architect #" is correct. Model # KEBC208K9T04 Serial # XT0418231
SOURCE:
  • 1073 Answers
SOURCE: Kitchen Aid Superba side by side
check the relay on the compressor
Posted on May 16, 2008
SOURCE: Kitchen Aid Superba Dishwasher
mix "CLR" (at stores) with water, pour it in, turn on diswasher (nothing in the machine) then stop it in the middle of first cycle before it drains. The "CLR" will get rid of calcium deposits that are clogging machine. I stopped my dishwasher for a few hours to let "CLR" work. This worked for me.
Posted on Jul 26, 2008
  • 142 Answers
SOURCE: Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Posted on Oct 01, 2008
  • 42 Answers
SOURCE: NO WATER IN ICE MAKER
From what you've described, it sounds like you have a defective inlet water-valve.
I would remove your outside rear bottom panel; disconnect the 2 prong wires connected to your ice-maker water valve (blue with black solenoids) and check for continuity using an ohm-meter setting. If defective, replace. Whats' your model #?
Posted on Jan 26, 2009
  • 9 Answers
SOURCE: compressor runs continuously, and center bar (heat dissipator) is extremely hot to touch.
Molly, The hot bar is a normal part of the sealed system (compressor) operation. The relay they told you about is on the back of the compressor and I would not recommend you changing that. The refrigerator is a balanced system, the freezer air removes the heat from the refrigerator side. If the compressor runs all the time, look for food close to the edge and not letting the doors close completely. Move items back. Don't over pack the freezer, the air must circulate. The refrigerator of today runs longer and uses less power that the old refrigerator. If you are still having issues with this model call a authorized Kitchen repair person in you area and ask how much they charge to come to your house and give an estimate.
Posted on May 01, 2009
We have a kitchen aid KGSA906PSS00 gas range. for the first time today the wife decided to run the self clean function. At some point through the self clean the oven shut off and the control panel died....
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Jan 27, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Kitchen aid model superba selectra oven door will not unlock after self clean control panel shows f3
One fellow with a similar model explained what he did to a similar model:
http://www.ehow.com/how_5499974_unlock-kitchenaid-superba-oven-locked.html
Another person with a different model mentioned hitting cancel 3 times. Another method was to press function, (5), then (2).
Aug 26, 2010 | Computers & Internet
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Jan 22, 2010 | KitchenAid KESC307 Electric Kitchen Range
I would like to clean in between the windows on the dooes of the oven. We have a kitchen aid superba double oven
You will have to dissassemble the door to clean between the glass. You may need to replace the gasket material when you do. It can be done but care will need to be taken during dissassembly, marking parts, so that during reassembly the unit will function correctly and not leak heat or cause the tempered glass to break. Good luck. I hope this is helpful.
Nov 12, 2009 | Sewing Machines
Kebs208d THE DOOR WILL NOT UNLOCK
HI, this is a major control fault. you will need to replace the Oven control asap if possible. It has failed.
Possible causes--
*Power surge
*Failed logic(IC)
*Oven Temp Sensor failuer that has resulted in extreme temps that has overheated the board.
Jun 07, 2009 | KitchenAid KEBC207 Electric Double Oven
Kitchen Aid Superba Double Oven
Remove the oven from the wall. Remove the rear panel.
The upper and lower ovens have a non-resettable thermal fuse that has blown.
Use a VOM to verify which fuse. After repair use Easy Off, not self clean.
May 24, 2009 | Jenn-Air Electric Double Oven
Self cleaning does not work
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$$$$
Mar 24, 2008 | KitchenAid KERC700LBS Electric Kitchen...
Kitchen Aid Double Convection Oven stopped during Self Cleaning
same thing happened to me yesterday took all day to figure it out was the themal fuse on the back of the oven the part number for my kitchen aid is 8300802 if you want the doors to unlock and reset the display you can take the leads off the fuse touch them together and the door will unlock however it is best to change the part took me 5 minutes once i knew what to look for
you have to remove the back panel and you will see the part with the number on it cost me 50 dollars but better than the 8o bucks to have a sevice guy come and do it next time i self clean i will pull the stove away from the wall to help keep it from ver heating
Feb 01, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
