Question about Fisher and Paykel Washing Machines
Why is my washing machine not filling up. sounds
Why is my washing machine not filling up. sounds like it is filling but only a trickle is coming through
  • krmowlam Jul 04, 2009
    How do I check the fill valve on the washing machine? Water pressure is fine from the faucet
    President:
  • 2,187 Answers
Washing machines would fill up with water using the water pressure from the tap and the fill valve to control it. Check the tap if the water does not come out as strong as expected, either the water pressure has gone down due to a leak or depending on the faucet or valve may not be opening correctly. The Fill valve of the washing machine may be faulty as well. It may not be opening correctly. It may be loose or totally faulty.
Posted on Jul 04, 2009
  • Nicolo Carlo Parazo Jul 04, 2009
    Washing machines do not differ much from each other. See link below for a more detailed description on the troubleshooting procedure.
    Fill Valve
Whirlpool lsb6000pq2 washing machine won't fill with water
Humming could be a blockage on the fill solonoid valve remove water fill hose and clean the filter at the valve it pulls out or use an old toothbrush
Jun 26, 2012 | Washing Machines
Cold water runs really slow when filling up washer,starts out normal but then goes to just a trickle until filled.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 30, 2011 | Washing Machines
Cold water trickling out.
heatman101
Feb 21, 2011 | Kenmore Washing Machines
When we use the cold water it is just trickling in. I cleaned the water inlet screen for the cold water on the back of the machine but it is still only a trickle. Is there another screen inside the back...
Often there is a screen at the inlet of the hose also...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hot water is a small trickle into the machine - warm water gives you a bit more water coming into the machine & cold water has a moderate bit of water coming into the machine. We have extremely hard...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 01, 2010 | Frigidaire FWS833A Top Load Washer
The cold water trickles in to fill the tub
sounds like you have checked the water coming out of the cold water so the fill valve requires replacement
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Cold water in the rinse cycle of the washer just trickles
Sounds like cold water solenoid is not opening all the way, its easy to replace, and is found inside the wash machine where the hose connects
Apr 25, 2009 | Whirlpool LSQ9600L Top Load Washer
F&p washing machine
Replace the dual inlet water valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
No water for rinse cycle
Take the fill hoses off the machine and clean out the filter inside, right where the hose attached to the machine. Also, check to make sure there are no filter washers in either end of the supply hoses. Sounds like you only have to check the cold water side in this case.
Nov 08, 2008 | Whirlpool Washing Machines
Washer fills slow only in the rinse cycle
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Sep 19, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
51 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
