I had my GE side by side for about 2 years. Things have been okay until a couple of months ago. Temp. is fine and then once or twice a week the ice starts melting and things start thawing. A couple hours later the temp goes back up and everything is fine for a few days. Any help would be most appreciated.
Hello, I can help you.
The thermostat cycles
the refrigerator on and off. The refrigerator normally runs as long as the
temperature inside the refrigerator is higher than the set temperature. If the
temperature inside the refrigerator is cold enough and the thermostat still does
not cycle off, the thermostat may be defective. If so, you need to replace it,
because it cannot be repaired. If the thermostat is not defective, you may have
a problem with the sealed (refrigerant) system, in which case you should contact
a qualified appliance repair technician.
Was this helpful?
Yes
No
Popular Solutions for GE Side by Side Refrigerator
Ice Cube machine stop working....Don't know why??? Ichange the water filter and reset it. still...
(More)
Ice Cube machine stop working....Don't know why??? Ichange the water filter and reset it. still nothing. Any suggests...
water is leaking from bottom of the refrigerator but no water is in the drain pan. Water supply to...
(More)
water is leaking from bottom of the refrigerator but no water is in the drain pan. Water supply to fridge has been cut off.
