Question about Samsung Cameras
Model l100 lens won't retract ,just beeps when powering on
While viewing stored photos screen goes blankand camera startup lamp keeps flashing.model samsungl100 8.2mp.
Posted on Jul 06, 2009
Canon power shot SD1200 IS elpf won't retract
This is a delicate operation but you can try this: tap the camera lens up on a towel over a hard surface (counter top or floor) while you expect the lens to retract as in turning off. It may be enough jarring force to get cams back in the helix that moved the lens. Hit it hard and flat. IF that doesnt work, try tapping the lens down while it tries to retract. I have heard that people get so frustrated with it that they slam the camera lens up on a desk and that fixes it!
Jan 30, 2018 | Canon PowerShot SD780 IS / IXUS 100 IS...
Hi I slipped in the garage and dropped the camera when it was on==batteries came out and lens of course didn't fully retract. Put batteries back in and the green light comes on and beeps but won't...
Sorry about your moms camera Terry... but it sounds like it needs the lens replaced. If the lens is stuck out at an angle you can *SNAP* the inner lens section back into place if you're lucky, and it will work again like normal.
I don't know your model, but a refurb lens can usually be installed for about $75 including return shipping. You should check the replacement cost of a used camera and see which is cheaper in the long run.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Samsung Cameras
It turns on but beeps 3 times then shuts off
Hello and Welcome to FixYa!
This indicates that the Camera lens is retracted, to D.I.Y be careful not to be aggressive with the Gadget If the lens is retracted, hold up the camera to your eye and look at the lens. If you see one end sticking out a little bit, push that side in and press the power button. It should work. If the lens isn't retracted, push the lens around until it is in its regular position. When you press the power button, it will retract and come out again and should work fine.
If the procedure above does not resolve the problem, your camera requires service, fill out our online service request form so that we can further diagnose and correct the problem.
I hope this will help you out, If you are still having issues/questions, do ask.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
Aug 13, 2010 | Samsung L100 Digital Camera
Samsung L100 camera, battery charger shows battery is fully charged, camera powers on, lens extends then immediately retracts and camera beeps three times
it sounds like a faulty battery try testing it with another battery and see if the problem persists if not then get a new battery,
let me know how it goes,
Jul 31, 2010 | Samsung L100 Digital Camera
My camera keeps turning off with a full battery and makes a beeping noise
There is something obstructing the lens. Camera turns off if it can't extend and retract the lens. Turn it downward, try blowing compressed air around the lens itself, or if all else fails spraying around the base with a light dusting of CRT cleaner (90% isopropal alcohol spray)
Apr 30, 2010 | Samsung L100 Digital Camera
My l100 samsung camera beeps three times when i push the power button and then wont come on? I tried to take the battery out and put it back in but that didnt help. i also took out the memory card but that...
Lens motor stalled.
Checkout the price of a repair at Samsung suppor.
Had this happen with the lens stuck in the retracted position. Rapped the camera on my palm to jostle the lens a bit, turned it on and back to normal.
Feb 07, 2010 | Nikon D100 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Samsung L100 digital camera beep problem
Hope this advice helps!
Aug 04, 2009 | Samsung L100 Digital Camera
My samsung L830 camera has jammed with the lens open and
Just had this happen to my L100. First, take out the battery and wait a couple hours for everything to cool down and discharge. Then place the battery back in. Then plug the USB cord into the camera and PC. Then turn the camera on and it should be okay. Just worked for mine.
Jul 15, 2009 | Samsung Digimax L830 Digital Camera
My lens won't retract or open and beeps 3 times and shuts off
I had a Polaroid i531 that would beep 3 times then shut down & the lens wouldn't retract.
I fixed it like this:
  1. Inspect the lens from all angles and you'll see that the lens assembly is out of sync. (My was looking upward ever so slightly)
  2. Using gentle finger pressure, press in the opposite direction of the abnormal lens direction
  3. I heard a snap, then I powered the camera on.
  4. Camera now works.
May 15, 2008 | Polaroid i531 Digital Camera
Cameras Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
