Question about Garden
White smoke first put in about 2 capfuls of 2 cycle engine oil into my mtd yard machine lawn mower.. several minutes into mowing, the engine started to slow a bit so i turned it off.. went to home depot and asked about oil.. bought 4 cycle.. and put bottle of it near the mower.. few days later son's friend put the entire bottle of oil into the lawn mower, which overflowed and pools .. now there is a lot of white smoke.. what is the easiest way to deal with this? just use paper towels to soak the oil up? take lawn mower to car wash and clean externally with degreaser?
  • 61 Answers
White smoke is most likely cause there is to much in the engine.. Only takes about half quart.. Clean with degreaser and garden hose on the outside..
Posted on Jul 04, 2009
What happened to cause the engine on a Snapper riding mower to emit white smoke?
maybe low on oil, black smoke is when theres oil in the muffler, could be a blown headgasket, pistion rings could be fried also
Jun 01, 2014 | Snapper Garden
Engine growing black smoke
Usually this is a sign of oil being in the ignition chamber. Check the oil level, if too high drain and refill to proper level. Also if you have hills or slopes in your yard make sure that you are mowing up and down not across. If you must mow across the slope make sure to do it with the oil to the downward side. Caution if you do this too often the engine will be deprived of oil all together and seize up.
Apr 18, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
My mtd yard machine (leaf blower) started billowing white smoke. I shut it off and now it won't start again.
First check the oil level. If its overfilled correct it. Then remove the spark plug and turn the engine over. Replace the spark plug.
Start the engine. Use a prime ( squirt carb cleaner into carb) if you need to. It may start smoking again. Thats OK as long as you know there is oil in it and you dont hear any strange noises. Let the unit run for about 5-10 minutes and see if the smoke clears up. Once it quits smoking stop it and check the oil.
Nov 11, 2012 | Garden
I have MTD Yard machine and don't know if it is 2 or 4 cycle. Oil should be-SAE30. Can I use oil for 4-cycle which they soid me i Can. Tire.(M otomaster)
If your mower has seperate fill caps for the oil and the gasoline, then you have a 4 cycle or 4 stroke engine. In this case use SAE HD30 motor oil. If there is only 1 fill cap and it says oil & fuel mix, then you have a 2 cycle or 2 stroke engine.
Good luck
Sep 10, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn mower running rough
adjust the carby. also u might want to replace the diaphragm in the carby. might work wonders
Mar 31, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
My B&S Yard Machine shoots out white smoke it also leaks out oil and gas mixed
If this is a 4 cycle mower (seperate places for gas and oil) and you are using a oil and gas mix as I am reading from your post that is your problem. When you use a gas&oil mix in a 4 cycle you get smoke and if fouls your spark plug. Also be more specific where the oil and gas mixed is leaking from. I SUGGEST THAT YOU DRAIN OUT THE GAS&OIL MIX AND CLEAN THE SPARK PLUG OR REPLACE AND FILL WITH STRAIGHT GAS AND SEE HOW IT RUNS.
Good luck
roundo4
Sep 03, 2009 | Mtd 22" Yard Machine Push Mower
Lawn Mower smoking/mufler leaking oil
I have a yardman lawn mower that is two years old. It is now blowing oil out the exhaust and also blue smoke. Any idea what is wrong?
Jul 22, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
What is gas mixture for 3.5 hp engine?
do not put oil in gas just 87 octane gas their should be a small pulg or cap where you can ck. the oil.you do not mix gas and oil with that moter or it will smoke bad
Apr 20, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
598 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
