Question about Palm Treo 650 Smartphone
My son's Treo 650 powers on (keypad lights up but screen does not light up.) My son attempted to switch the case from the silver to a black and now it will not work. Help?
  • 24 Answers
It may need a software rest if it don"t work go to reinstal software first chake it out
  1. Hard reset:
  2. Press and hold the Power (on/off) button on the front panel of your device.
  3. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  4. If you see a progress bar (see below), keep holding the Power button.
  5. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  6. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Warning: A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything.
HotSync note:Some third-party applications change the way your device backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks,
Posted on Jul 04, 2009
Hi how to unlock my palm 650 to used outside of USA
You can use the Unlock code to Unlock Your Palm-One Tero 650 model Phone,You can get the Unlock code from here
Wickedunlock and follow the instructions and Unlock it step by step..
Palm One Treo 650 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Palm One Treo 650 mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Treo 650 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Palm One Treo 650 with an ACCEPTED SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application",
3 - Type on Virtual Keyboard *#*#CODE#,
4 - Select with PEN "Numer" and Palm One Treo 650 will show that it's unlocked now!
or
1 - Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
2 - Enter the Unlock Code we send to you.
or
1. Remove Palm One Treo 650 battery, unplug cable,
2. Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
3. 'Sim not allowed' is displayed, click OK,
4. Go to the dial pad, and dial *#*#CODE#,
CODE: The unique unlock code for your Palm One Treo 650.
ACCEPTED : We mean, to use a sim card from the network your Palm One Treo 650 is locked to.
NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Palm One Treo 650 is locked to.
Jul 10, 2011 | Palm Treo 650 Smartphone
WHEN I CHARGE MY TREO 650 THE RED LIGHT AND CHARG...
Charging circuit cause trouble due to heat, please see a technician or first use "restore factory settings"
Regards
Marshal
Dhaka, Bangladesh
bdman2010@hotmail.com
May 20, 2010 | Palm Treo 650 Handheld
How can i turn off the annoying LED light?
There are several possibilities. One is a little freeware application called LEDOff. Just Google "palm ledoff" and go to the first site you see. It says it's for the Treo 600 but it works great on my 650.
The other solution is to put some kind of barrier over the light, like electrical tape. If you're feeling adventurous, you could even open the case and put the tape on the inside so it doesn't ruin the look of your device.
I can't for the life of me figure out why the Treo designers used such a bloody bright LED. I mean, it's like a laser! If you try to look at the screen when it's charging you'll likely get a headache. But the utility I mentioned even turns off the charge light.
Dec 02, 2008 | Palm Treo 650 Handheld
Treo 650 phones turns off by itself
funny thing... the older palm treos like this one have some glitches. these glitches can normally be fixed by changing some of the settings.
1) go to your home screen, and select PREFS
2)select power
3) set your brightness level all the way to the right (NOTE: it takes more power to dim the screen then it does to brighten the screen.)
4) set auto off after: to the highest number allowed
please let me know if this helps!
Nov 25, 2008 | Palm Treo 650 Handheld
Treo 650
Try a Zero Reset - but you will loose all your data
Sep 25, 2008 | Palm Treo 650 Handheld
Palm Treo 650 Unlock Code.
Call your service provider.
Jul 16, 2008 | Palm Treo 650 Handheld
Treo 650
my treo 650 just turned of the light of the screen.thought it was only battery.i pulled out the battery then put it back again,the light is on and say palmOne with a bar loading.then the light was gone again.try to sign on but nothing does
Jun 24, 2008 | Palm Treo 650 Handheld
TREO 650
I HAD THE SAME PROBLEM, I TRIED OVER 7 TIMES TO GET REPLACMENT SCREEN TO WORK AND NO LUCK UNTIL I REALLY FORCED THE CONNECTOR INTO CLAMP YOU HAVE TO PUSH TAB FULLY INTO SLOT IF NOT YOU GET NO POWER SUPPLY!
Oct 15, 2007 | Palm Treo 650 Handheld
Question Mark error
hi try "Power Down Reset": http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(887) then try this: http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(26419) hope this helps good luck
Apr 07, 2006 | Palm Treo 650 Handheld
Auto-off not working
I heard this happens after updating the Treo 650 with the new version 1.17. Is this your case? If so just remove the new update... Anyway, you can try the soft restart or even Performing a system reset(from the user guide p.170): ".. Performing a soft reset A soft reset is similar to restarting a computer. If your Treo is not responding or you have trouble synchronizing with your computer, a soft reset may help. 1. Press the Battery Door Release button and slide the battery door downward to remove it from your Treo. 2. Use the stylus tip to gently press the reset button on the back of your Treo. .."
Jan 03, 2006 | Palm Treo 650 Handheld
Palm Treo 650 Smartphone Logo
222 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
