Question about Exercise & Fitness
Sportcraft treadmill has an error 3 light on panel and shuts off
Treadmill runs a few seconds then shuts off and a 3 appears on the panel
erpaalai
  • 999 Answers
SOURCE: turned on, runs a few seconds, shuts off with a #3 on display
Contact the manufacturer. You need the optical disc. It is the speed sensor. Eric For Treadmill replacement parts, please contact our Consumer Affairs Dept. at (800) 526 - 0244
Posted on Aug 11, 2009
SOURCE: Sportcraft TX 2.5 treadmill - error code 3 - stops
Sorry I dont have the solution but I have the same problem.
Read somewhere that Sportcraft control boards had
a design flaw.
Posted on Dec 20, 2009
  • 218 Answers
SOURCE: I have aI have a sportcraft treadmill that stops working after 7
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Posted on Aug 13, 2010
SOURCE: Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
Posted on Jan 08, 2011
ZJLimited
  • 17970 Answers
SOURCE: e5 error code on sportcraft tx400 treadmill
E5 error code means that your treadmill sensor goes out and require calibration. Just try with TechnoGym and following the procedure to calibrate the sensor.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Posted on Nov 24, 2011
We picked a TX 440 from a friend and the error button shuts it off
If you wish to get some details About treadmill repair; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 11, 2016 | Sportcraft Tx 455 Sportscraft Treadmill...
Sportcraft tx 2.5 shows code 3 and stops after a few seconds of running time.
If you wish to get some details treadmill repair and error code ; check the site linked here. Pull up older posts.
Sep 07, 2016 | Sportcraft Exercise & Fitness
The treadmill shuts off after a minute, producing an Error message.
see the video proceed according and lube the rollers bearing front+back too.
God bless you
Nov 03, 2013 | Sportcraft Tx 455 Sportscraft Treadmill...
A backwards E appears on my treadmill model 3-1-04-050 FH what does this mean?
Read your instruction manual, section troubleshooting for indication.
However you must adjut THE reed switch, see the diagram attached, clean, and tigh the connector wires very well. God bless you.
Run the software calibration for diagnose, and troubleshooting too.
Jun 07, 2012 | Sportcraft Tx 455 Sportscraft Treadmill...
SPORT TRac treadmill shuts off after a few seconds
1) LUBE THE DECK BELT, this produce enough friction for shutdown the machine.
2) LUBE the rollers bearing very well.
3) Test the input voltage motor, if there are VOLTAGE, the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
See the block diagram. God bless you
May 27, 2012 | Sportcraft Exercise & Fitness
My Sportcraft TX-400 Treadmill shuts off after 7 seconds
Dear sIR:
This by lack of LUBE, in your schedule maintenance DECK BELT. maybe the belt is worn.
2) Lube the roller bearing.
3) Align the belt see the diagrams
4) Test the input voltage motor, if there are voltage motor, the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Now you can RUN the software calibration for diagnose, troubleshooting. See my personal TIPS for HELPs too.
sincerely. God bless you
May 06, 2012 | Sportcraft TX 400 Walking Belt
E5 error code on sportcraft tx400 treadmill
E5 erorr code for my gait keeper treadmill ,it starts up after few seconds ,it stops
and error code appear.Can you tell me what this means? How to solve this problems?
Nov 24, 2011 | Exercise & Fitness
Feb 16, 2010 | RTO Image 15.0R Treadmill Walking Belt
Turned on, runs a few seconds, shuts off with a #3 on display
Aug 06, 2009 | Exercise & Fitness
Sportcraft TX 2.5 treadmill - error code 3 - stops after a few seconds of operation. ??? Thanks for any advice
a design flaw.
Jun 28, 2009 | Exercise & Fitness
Exercise & Fitness Logo
379 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
