Question about Labtec Spin 45 Computer Speakers
How do I open them?
I need to open the speakers. How do I do that? I opened the two screws from the back but it doesn't pop out?
  • funpro2000 Nov 12, 2007
    Actually, there are two more screws underneath the grill in front of the speaker. I had to pull the grill off (stuck with glue) and then open those screws. In any case, it turned out that the volume knob was broken badly and I couldn't find a way to fix it.
  • 537 Answers
Is there a seam somewhere where you could carefully separate the two halves with a tiny screwdriver. Or look for any obvious tabs that could be used to unlock the two halves.
Posted on Nov 12, 2007
How to open hp 2310m monitor
1) Take off the stand, and pop the back hp symbol off. Take out the four screws under the hp piece, and flip the monitor over.
2) On the front of the monitor, pry and pop off the black ring (bezel?) around the screen. This piece is not held on by any screws, so this part should be simple.
3) Now that you have undone all the screws, you can lift the screen out of the casing, but be careful about all the wires. They all have simple pull-apart connectors, but you wouldn't want to break any wires. The only connections should be the left speaker, right speaker, and the button panel on the bottom.
I'm sure you can take it from there, depending on what you're doing. Hope this helps!
Nov 23, 2012 | Computers & Internet
My 95 buick le sabre needs new front speakers but i cant figure out how to get off the front plastic piece
the door speakers?
there is one screw near the handle to open door, there is a screw on the outer edge of the door panel, you pop off the switch cluster and there is 2 screws in there, the door panel will have clips that hold it on, gently pull to pop them loose, the speaker is at bottom right, if you have concert sound II there is also a tweeter above the speaker
Sep 18, 2011 | 1995 Buick LeSabre
How do I remove the door panel on a 1999 Chysler concorde?
for the front doors:
Remove the speaker cover.
Remove screws holding the speaker.
Inside the door handle, there's a little cover that you can open with a flathead screwdriver. Flip it open then remove the screw inside. Another one of these is in the little armrest cubby. Same deal, flip it open then remove the screw.
If you have sail speakers (close to the window), remove these too. Gently pry the cover off, then remove screws.
The dip on the door towards the front of the car, there are 2 screw to be removed, they are in there deep but easily come out.
At the bottom, there are 3 more screws to remove.
Once you have these screws off, you can feel the door panel start to come off. There are plastic pieces inside the door panel that are a pain to get the door panel off of; you'll have to lift it to remove the panel. Be aware these might break. I found replacements at an autoparts store. One of mine doesn't have 1 of these (2 on each panel IIRC) but there is no noticeable difference.
As stated, this is for the fronts. The rears should be somewhat similar, just screws to remove.
Carefully put the panel back on, making sure the panel rests into the clips in the door panel, or it might feel loose or look off. You might have to mess with the door lock when you put the door panel back on. Good luck.
Aug 02, 2011 | 1999 Chrysler Concorde
first check that the cabling going to the right speaker is not damaged then see if the plug for the speakers is damaged. if both are fine the speaker can be dissembled by removing the screws in the back or bottom of the unit and then popping them apart
Mar 05, 2011 | Dell A215 Computer Speakers
Opening the speaker box, Peavey KB 60 Amp
A couple of top screws and some on the back lip of the chassis . The amp slides out but be careful not to pop the speaker leads I own a KB50 and have worked on other KB amps.
Sounds like you need a new reverb spring set.
Peavey is very good for parts
Mar 29, 2010 | Audio Players & Recorders
What kind of tool is needed to open mackie srm450 speakers. I need to replace tweeter.
12" phillips screw driver total of 16 or 17 screws on back, then open like a **** its easy!
Jul 29, 2009 | Mackie SRM-450 System
Replacing the diaphragms on the eon power 15
Yes - Simply face the speaker down - unscrew all of the screws (don't forget to remove the handle and the 2 under it) - once they are all lose, carefully stand the speaker upright and gently pop apart - as it is opening you will need to disconnect some wire harnesses and will need to undo the ground wires. DONE
Apr 07, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Anyone know how to pop the radio out?
try removing the speakers from the cab and trying known good speakers. That way you will know if there's any power or not.Otherwise you will have to remove some of the panels on the dash to gain access to the reciever. After you can open upa space to access the reciever, it is only a matter of removing a feww screws and the nut at the back that holds the reciever stable.remove radio fuse before doing anything.
Nov 06, 2008 | 1998 Jeep Cherokee
Drivers side window
Hi, callen
Look under the door pocket, you may find some deep recesses inside which are some securing screws.
Look around the handle which you use to pull the door shut, it may have screw covers which need to be popped out.
Look behind the door lever which you use to open the door, I think there may be a screw cover in there with a screw behind it.
And last but not least. if your door panel has one of those little tweeter speakers built into it as well as the main speaker, then pop the speaker out and you may find a screw behind there.
Very best regards
Jun 20, 2008 | 1999 Volkswagen Passat
My speaker on my Sony Ericsson 300i isnt working
You need a torque six screwdriver to open the phone up. The screws are under the battery.
Sep 27, 2007 | Sony Ericsson W300 Cellular Phone
Labtec Spin 45 Computer Speakers Logo
115 people viewed this question
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
