Question about Friedrich CP12C10 Wall/Window Air Conditioner
Friedrich AC through the wall ac leaking water out front vent
Just purchased new Quietmaster. Works great but water(condensation)is coming out the front vent. It's installed through the wall and the installation seems correct(angle of the chassis) Any Ideas?
  • 6,927 Answers
Pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Posted on Jul 04, 2009
Friedrich Model SQ06J10 AC 'in wall' leaking water inside from front bottom right corner
I think 2 things will correct this problem. 1. be certain that the unit is tilted to theoutside about 1 inch or so. 2. be certain that the filter is clean.. Let me know if it does not solve it . have a great day
Jul 23, 2011 | Heating & Cooling
Where is the drain hole on my frederich quietmaster wall air conditioner?
Hello, if there is no drain hole under the unit then it uses the fan blade to sling water on the condenser to evaporate the condensate. Some window units are made this way instaed of using a drain hole.
Jul 12, 2011 | Friedrich QuietMaster KM24L30 Wall/Window...
Where is the vent on my Friedrich AC unit? I don't know how to close or open it.
the fresh air vent open close tab should be located somewhere along the vent louvers look at the bottem of them starting from right to left its their use a flashlight to see it good luck ..let me know /joe/
Aug 25, 2010 | Friedrich QuietMaster RS10J10 Air...
Best height of inside unit of a split AC
which type of mounting is suggested wall or ceiling, if it is suggested that wall mount is nominal then the height is optional, mount it as high as possible. If ceiling mount is suggested then closet to outside wall as possible
Jul 26, 2009 | Friedrich QuietMaster RS10J10 Air...
Condensate blowing thru discharge vents when operating on high cool, unit is pitched 3/8in. there is no standing water in chassis tray, this unit just installed new out of the box
Try a lower fan speed, sometimes the velocity of the fan combined with high humidity lifts the moisture off the fins instead of allowing the water to properly drop to the pan.
Jul 10, 2009 | Friedrich QuietMaster Deluxe RS12L10 Air...
My AC needs a new 220 cable
If the damage is close to the end of the cable, simply get a replacement plug end from a home repair store and put it on.
Cut the old plug off and install the new plug.
when you go to buy the cord end, take the old one with you so you get the correct configuration.
May 31, 2009 | Friedrich QuietMaster SS12L10 Air...
Condensate blown out of the AC vents in front of passenger seat
U need to crawl under the car and clear the ac condensate drain, it is a rubber pipe on the passenger side that sticks out of the bottom of the engine firewall, they get clogged and water builds up in the ac and this problem happens.
May 14, 2009 | 1999 Mitsubishi Montero
Friedrich RS10J10-C: Only half the coils are chilled...
If the evaporator coil is only half coated with water, this means it is low on Freon. You need a repairman to fix the leak and add Freon, but this costs way over a hundred dollars.
Jul 23, 2008 | Friedrich QuietMaster RS10J10 Air...
Friedrich air conditioner
Dear cmr 1,
As you have mentioned that it look like the fan hitting something, this is possible. This kind of problem can occur while transporting the machine. Some times the fan becomes loose because of viberation. So the fan has to be realign. Regarding the tilt it is okay to have 1/4 inch tilt backwards. Since the air-conditioner is brand new it is advisable to contact the company.
regards,
ramesh22
Jun 25, 2008 | Friedrich QuietMaster Deluxe RS12L10 Air...
Friedrich CP12C10 Wall/Window Air Conditioner Logo
1,216 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
