Question about Intertherm P3RA-048K Air Conditioner
Water leaking onto floor
I have seen a couple of posts with similar problems, Intertherm A/C water leaking around the drain pan onto the floor. The drain lines are clear. This has happenned to me several times and created much aggravation. Through trial and error I solved the problem at least temporarily. I re-leveled the unit and took the coils out cleaned them and reinserted. The coils didn't look excessively dirty but they may have been clogged inside. The problem usually happens when it is extremely humid outside, and the unit is located in a humid area of the house(garage). This is possibly due to the excessive amounts of water that the unit is taking out of the air. If anybody knows of another solution, help is appreciated.
  • tquigley Jul 16, 2009
    The definite fix is- adding a trap to the drain line. I was using an evacuation pump for the condensation overflow so I thought that I did not need a P trap. I was totally wrong. For the life of the unit, 5-6 years there has always been a little bit of water accumulating around the base of the unit, and around once a year when it would get extremely humid outside and/or my filter/coils would get a little dirty causing increased resistance, air would suck through the condensate line, blocking proper drainage, and causing mess on the floor. Take the unit apart-works fine because there is no resistance, put cover back on and dripping again. What a headache for several years. A $2.00 running trap, solved my problem definitely. Thanks!
  • jim christie
    jim christie Sep 01, 2014
    what is the running trap and where is it .
  • 116 Answers
At night disconnect power use flash light and mirror check to see if coil is stopped up if unit is up flow coil fan heat kit make sure there is a trap in the drain line or unit will pull air into system most likley cause is dirty coil hope this helps unit could also have dirty fan blades low air flow or starting to freeze the coil due to low freeon charge if down flow supply duct under unit ths is not good due to heat kit on bottom of unit can get wet! hope this helps with your problem
Posted on Jul 04, 2009
I have a Intertherm Heat Pump system in my Manufactured Home, Model # E2EB-015HB; Serial # E2E0121006692. Condensation is forming on the Coils and the water fills up the area under the coils, drips down...
There is a drip pan bit the middle is open to allow air flow through the coil and into your ducting. If the drain for the drip pan is clogged it will fill up and overflow onto your furnace and then to the floor.If that is what is happening then clean out the drain tube running down the front of the furnace and it should empty the drip pan and solve your problem.
You also need to have your furnace checked for water damage in the electrical components, if these have gotten wet then you run the risk of a fire. Please consider calling an expert in your area to inspect your furnace and make sure the drain line is clear.
Jun 13, 2011 | Intertherm Heating & Cooling
I have a two door 600 liter fridge the freezer side has a water drain hose which I don't know where the water drains to.I have cleared the frozen water from the drain hose,a couple of times but I know the...
The hole in the bottom of the freezer section all the way in the back is clogged. Use a metal coat hanger or something similar to stick in the hole and try to clear out the clog. The water drains to a pan underneath the fridge, and the heat produced by the compressor should evaporate the water.
Dec 10, 2010 | Maytag Refrigerators
Intertherm Air Handler Coil leaking water
replace it it's junk - going to do that this time because this is the fourth year of the same problem on the hottest days this intertherm junk downflow ac unit condensates where it will not and con not be captured by the pan - built by relatives of the guy who designed the titanic -
Apr 07, 2010 | Intertherm P3RA-024K Air Conditioner
Water leaks into right side floor board during a blowing rain?
My 06 was leaking during rain also. It turned out to be the sunroof. There are two drain tubes in the front of the sunroof that run the water down the corners to the ground and two drain tubes that drain water out the back corners. The water would seep around the glass, which is expected, but both of the tubes on the front of mine were plugged, and the water would overflow behind the dash and fill my floorboards. If my H3 was leaning to the left during a storm then the drivers side would be full of water. If leaning right, then the passenger side. I had to open sunroof and blow compressed air into the drain holes to clear them, but be careful, too much air will separate tubes from sunroof and then you will have to remove the inside paneling around sunroof to get to tubes and reconnect. You may only have one side plugged. you can test it by opening sunroof and pour a little water in the small catch pan in the front of the sunroof and see if it drains as expected (to the ground under the firewall on left AND right side). You can see the holes in each corner of catch pan to drain the water. Plug one with your finger, then the other to find the plugged side. Good luck!! Hope this helps!!
Jan 26, 2010 | 2009 Hummer H3
Water leaks into freezer bottom & floor
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 16, 2009 | Kenmore Refrigerators
So water leaks out onto floor-Jennair side by side
THERE IS A DRAIN LINE HEATER ON MOST UNITS now days, if yours is an older one what you need to do is make sure that it's level, and that the drain line is cleared so that the water has a place to go when it thaws during the defrost cycle.
Jan 27, 2009 | Refrigerators
Water collecting in bottom of freezer coming from back grill.
To poshodian: There are a few more posts about this problem. Of course, in order to fix it, you have to remove the panel hiding the condenser coils behind the grill and showing the drain hole.
This is what I just posted on one of them:
I’ve had my Maytag 2454 fridge for 8 years. But only this week did the same problem show up as cathy824 and lew223. When I poked a drink stirrer into the top of the drain hole, it was hard as a rock. Not knowing why condensate from the coils was not draining into the hole and tubing that would empty the water into the pan evaporator on the bottom of the fridge, I took everything apart in the back and messed around with the black rubber elbow at the other end of the drain plug. I shouldn’t have bothered, because what I finally did was to pour boiling, boiling hot water over the drain hole to melt the ice and gunk that was frozen solid in the drain tubing. While I was doing that, I poked the stirrer into the hole, washing the gunk down the drain and into the very dry evaporator pan. Keep pouring hot water into the drain hole until you’re satisfied that water can flow freely into the pan.
That solved the problem of condensate water freezing on the bottom of the freezer and running onto the kitchen floor. Thanks to lew223 for the fix! The fridge should be good for another 8 years now.
Jan 13, 2009 | Maytag MSD2454G Side by Side Refrigerator
Water leaking onto floor from refrigerator/freezer
The defrost drain is stopped up. Without taking anything apart, the easiest way to clear the drain is to blow compressed air through the drain tube which is at the back of the Fridge. You'll see it..... it drains water into the drip pan. Hope this helps !
Oct 09, 2017 | Refrigerators
Intertherm P3RA-048K Air Conditioner Logo
451 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
