Question about Dryers
Gas dryer does not stay hot.
Hi My Maytag gae dryer will not keep the heat going. after about 5 or 10 minutes it just blows cold air. any ideas would be wlecomed. thank you
  • 11 more comments
  • garynett Jul 04, 2009
    the dryer does get hot for a while and then goes cold during the cycle. could this be caused by the issues you mentioned?
  • 10,865 Answers
Hello. I can help you. Here are all of the possible problems
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
Posted on Jul 04, 2009
Dryer wont heat for more than 10 minutes when cold
did you clean the vent line?THAT COULD MAKE IT RUN HOT THE AIR CAN'T BLOW OUTSIDE,BUT WITH THE DRYER HAVING HEAT WHEN IT STARTS AND THEN AFTER LIKE 10 MINUTES NO HEAT IT SOUNDS LIKE YOU HAVE BAD GAS COILS,WHEN THE COILS ARE STARTING TO FAIL THEY WILL WORK FOR LIKE THE FIRST 10 TO 20 MINUTES AND WHEN THEY HEAT UP NO GAS,WHEN THE COOL THEY WILL WORK AGAIN,I WOULD CHANGE THE COILS AND CLEAN OUT THE DRYER AND VENT LINE,THIS SHOULD BE DONE ONCE A YEAR SO YOU DON'T HAVE A FIRE AND YOUR CLOTHES WILL DRY ON TIME,EVERYONE THINKS SOMETHING IS WRONG WITH THE DRYER AND ALL THAT HAPPENS IS THE VENT LINE AND THE DUCT WHERE THE LINT FILTER SLIDES INTO FILLS WITH LINT AND THE AIR CAN'T BLOW AROUND GOOD ANYMORE,ALSO WITH A SHOP VAC VAC UP THE LINT WHERE THE BURNER AND MOTOR IS AND THEN SET THE VAC UP TO BLOW AND BLOW THE MOTOR AND GAS BURNER OUT,DO THIS AND YOU'LL HARDLY HAVE ANY PROBLEMS WITH THE DRYER
Sep 30, 2017 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
Heat wont stay on
Replace the 2 gas valve coils, check the link below to have an idea of how they look like.
Maytag Dryer Gas Valve Ignition Solenoid Coil Kit 279834
Jan 14, 2014 | Whirlpool LGB6300 Gas Dryer
Why is my dryer blowing out cold air?
It sounds as though you have a defective heating element.
May 31, 2012 | Maytag Atlantis MDG7400AW Gas Dryer
Works but does not blow hot air...just cold
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 23, 2010 | Maytag PYE2300AY Electric Dryer
Dryer runs for 20 minutes then blows cool air, if you let sit for 5 minutes it will blow hot air again but only for a few minutes. I replaced the thermo fuse, and the hi-limit thermostat. I just had the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 09, 2010 | Maytag MDG308DAWW Gas Dryer
No heat in gas dryer, gas good, elec good??
if the heat is on when the dryer is cold then shuts down after 15 to 30 minutes and doesn't lite for a long while you have bad gas coils,the gas should come on until it hits temp. then it shuts down,when the dryer calls for heat it will turn back on,if it stays on for short periods of time you might need to clean out the dryer,this will shut the gas down to soon,you need to clean out the duct that the lint filter slides into,blow out the vent line,make sure the air is blowing outside with nothing blocking it and vac out the inside of dryer where the motor is
Mar 12, 2010 | Maytag Dryers
Maytag gas dryer will heat for about one minute
The gas coils on the gas valve have gone bad. These are located on the gas valve and will be 2 solenoids. Replace them both and should be able to get as a set. 12001349 should be the number and cost less than 60.00 for the set. Good luck and thank you for using Fix Ya.
Feb 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Heat will not stay on
Hi, very common problem.
The problem is with the gas coils.
When they get weak, they only come on for about 10 minutes and then the machine will blow cold air. There are 2 of them with one being the booster coil. They come in a pair and run less than $20.
Best of luck. Please e-mail me if you have any other questions.
Sep 15, 2009 | Whirlpool LGN2000LWH Gas Dryer
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Dryers Logo
138 people viewed this question
Top Dryers Experts
