Question about Sony CRX 175A CD-RW Burner
Tray does not open and the light lits green all the time. how to open the tray?
  • 1,959 Answers
There should be a pinhole below the tray. Take a pin or paperclip and insert it in the pinhole to eject the tray.
Posted on Jul 04, 2009
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
Once my game is loaded into tray the screen comes up and tells me to open back up and close again. This occurs all the time not just with one game. Any suggestions???
Yes. First when the tray is opened watch the green light . It should
blink then stay on steady.
When the tray is closesing you should see a blinking
green light in the center of the ring of lights .When the tray
is fully closed and engaged the light will stop blinking then you
should hear the drive spin-up. If not open the tray then close
it ,just as the tray is almost closed push it close hard then the
green flashing light should be steady on.
This is cause mostly by friction in the drive or a bent
leaf switch that the tray engages to tell the console
the state of the tray .
The remedy is either you or a shop
will need to open the drive and remove the frictions
points which very from drive to drive. and check the
leaf switches . cost 40.00 or so . or you could
simply buy a "new" drive on ebay and swap the
Drives P.C. board from the old drive to the new one
price 40.00 but you supply the labor.
I gave you more info than you need but this is
common problem and I hope it will help others also
If you have any questions please feel free to ask
Rob
Nov 14, 2010 | Microsoft Xbox 360 Console
The triangle light is lit on the panel. What does
tooner goes to low or paper stucking any where in paper path..check for both ur problem will be resolved
Jul 30, 2010 | HP LaserJet P2015dn Printer
Blinking green light
The blinking green light is because your 360 is not understanding that the disc tray is closed. That's also the reason that the tray comes back open. It's not getting fully closed. Next time you insert a gamepush the drive closed with your hand. You'll know the drive is closed when the light stops blinking.
Dec 26, 2009 | Microsoft Xbox 360 Console
My xbox now have an blinking green light and the tray would come out
The blinking green light is because your 360 is not understanding that the disc tray is closed. That's also the reason that the tray comes back open. It's not getting fully closed. Next time you insert a game push the drive closed with your hand. You'll know the drive is closed when the light stops blinking.
Dec 23, 2009 | Microsoft Xbox 360 Console
Ps2 cd tray does not open and the eject button light flashes
This is the tray getting stuck on the PS2 shell/casing. I can fix mine as it does the same thing but I tap it one quick time after I hit the eject button and it will usually open. Don't try to pry the tray open or this will make the problem worse.
Jan 08, 2009 | Sony PlayStation 2 (PS2) Console
How to change paper tray on pixma ip4000 canon?
There is a button I believe just above the USB port on the front of the machine. The picture is of a printer and there are two areas that will lit up. If the light is on the bar that is in the vertical direction, this indicates you are using the top feeder. If the bar is lit that is horizontal you are using the paper tray feeder. The Default is normally on the top feeder. Most people do not even realize there is a paper tray on these machines. They are hidden well.
To change tray settings simply push the gray button found under the picture of the printer with the vertical and hrizontal bars usually lit in green!
Nov 14, 2008 | Office Equipment & Supplies
Print photo
all you need to do is load 4x6 on your 4x6 photo tray(the small tray) then pupsh the tray all the way in until the green light on the right lits up then you are all set.
Oct 22, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer ML2010 not responding
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 15, 2008 | Samsung ML 2010 Laser Printer
Sony CRX 175A CD-RW Burner Logo
98 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
