Question about HP Pavilion F1703 17" LCD Monitor
After 5 or 10 min, why?
After 5 or 10 min, why does it goes black ?
  • HP Master
  • 2,404 Answers
You have the power options set in the control panel for the monitor to go into sleep mode. Best thing to do is to go into the control panel and go into power options. From there you can tell when you want the monitor, hard drive, etc to turn off or even set them to never turn off. I usually turn all of that stuff off.
Also make sure your screensaver is set to the way you want, that could cause the monitor to turn to black as well, you can have your screensaver come on as often as you want or even turn that off to.
Try all of those i mentioned and that should take care of your problems.
Posted on Jul 04, 2009
Tv goes on normaly but after about 10 min the image goes off the sound stays ok but with a black screen
open the TV and test the capacitor that supply voltage to the variable resistor the control the brightness.
Jul 03, 2011 | Televison & Video
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Computer turns on, starts up ok... can hear the start up music, hard drive lightworks ok, screen goes black... after 10 mins. when this prob. started.... now it stays on (see the icons) for abt 1 min.- 30...
have you downloaded any new software? it might be the culprit if not try restoring to an earlier date when the system was working properly (like at least 4 wks ago) .. work quick since you only have 1.5 min go to start/all prog/access/systems tools/system restore...note when it shuts down it will boot up auto and you must click okay when prompt
Aug 19, 2010 | HP Pavilion dv9000z Notebook
Unit powers up for 5- 10 min good picture....then it goes black power light goes from green to red and flashes once and solid and repeats pattern .........if i go up to unit and push power off and back on...
There is circuit problem inside. For safety reasons power might get shut down! Unless the fault is rectified, this problem will continue. Do not attempt switching ON again & again. Get authorised service center assistance.
Apr 20, 2010 | Televison & Video
Picture goes black mins after watching
Bad flyback transformer. It has a short in the winding making the Horizontal output transistor heat up so when its too hot the set goes into protection.
Aug 25, 2009 | RCA D52W23 52" HDTV CRT TV
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Every 10 mins my monitor goes black and then the picture pops back up
Its the poblem of SCREENSAVER which gets activated every 10 minutes.
In Control Panel, go to Display Settings / Personalise - - - - -> In Screen Saver select NONE.
Your problem will be solved for sure.
Apr 24, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Plays for 10-15 min.then pic.goes black,sounds stays on.
Resolder FBT pinns flyback transfomer on deflection board also CK capacitors 3 of them cp114,120,150 if anmy of them is puffewd up on top it is bad.cp150 2200uf 16v other 2 are 220uf 35v replace all 3.
Jan 28, 2009 | RCA R52WH73 Projection Television
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Pc screen goes black green light stays on
Well since you seem to have tried a bunch of thing why nor go a bit more and replace your video card. Below is a link to your PC:
http://support.packardbell.com/uk/item/index.php?pn=P280110001&g=1400
Dec 21, 2007 | Computers & Internet
HP Pavilion F1703 17" LCD Monitor Logo
96 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
